Old 04-29-2012, 09:30 PM   #21
Master Of Disaster
socalelect's Avatar
at least they attempted to offset to the LB on the roof
Old 04-29-2012, 09:38 PM   #22
Boomer's Avatar
Iraq?
Boomer is offline   Reply With Quote
Old 04-30-2012, 01:58 AM   #23
I'd recommend a 5-gallon gas can, filled with a 50/50 mixture of gasoline and kerosene. Gasoline for immediate flame spread, and kerosene for that slooooow burn.
Naw., go straght diesel fuel it take little more time but for sure hot as heck and how easy to sang 20 liter of Kerosene fuel ?
Merci,
Marc
Old 04-30-2012, 02:00 AM   #24
3Xdad.,
Is the gaz meter is below of the electrique panel ?
Merci,
Marc
Old 04-30-2012, 05:58 AM   #25
Do it. Or someone else will.
The Following User Says Thank You to bobelectric For This Useful Post:
3xdad (04-30-2012)
Old 04-30-2012, 08:48 AM   #26
ET rocks
3xdad's Avatar
Originally Posted by frenchelectrican View Post
3Xdad.,
Merci,
Marc
No gas meter, just the pipes. The new service needs to be on the other corner to the left of the old meter.
"Starbucks makes you vote funny" ..macmikeman
"I'm gonna try something I call a compliment sandwich..." ..Big John
"i do love me some gutter" ..Eric
3xdad is online now   Reply With Quote
Old 04-30-2012, 09:52 AM   #27
Podagrower's Avatar
Originally Posted by 3xdad View Post
Yeah, rigid mast for sure if i mount on the house, but was unsure about the rock ledge being in the working space. The existing location is def. a no go with that gas pipe and what not.
Since the rock ledge is not part of your electrical assembly, it is technically in the way of working space. I have had to build a pad to the height of the obstruction, the width and depth of required working space, in that situation before. Once.
But, I have also done many services with a ledge or foundation sticking out where the inspector didn't say anything.
Podagrower is offline   Reply With Quote
The Following User Says Thank You to Podagrower For This Useful Post:
3xdad (04-30-2012)
Old 04-30-2012, 12:47 PM   #28
Amish Electrician's Avatar
I'd go for strut, supporting a rigid mast. With strut, you can make sure your lags go into solid framing, and you can deal with the uneven nature of the stucco. Heck, if you have a multi-master, you can even recess the strut into the stucco.
The strut will also 'disappear' when they replace the stucco.
Second choice is a very large piece of very thick, very weatherproofed plywood. If you can't be sure of hitting framing, you can use 1/4" toggle bolts. Even so, considering the uneven nature of stucco, you'd be well advised to either stand the plywood off the wall 1/4", or to cut out the stucco and inset the sheet. A little stucco can be used to cover the board and make it blend with the house.
In either event, that dryer vent has got to go.
Amish Electrician is offline   Reply With Quote
The Following User Says Thank You to Amish Electrician For This Useful Post:
3xdad (04-30-2012)
Old 04-30-2012, 10:04 PM   #29
Originally Posted by electricmanscott View Post
Are you sure you're in New Mexico?
jefft110 is offline   Reply With Quote
Old 04-30-2012, 10:31 PM   #30
ET rocks
3xdad's Avatar
Oh yeah, Josue. Where the heck has he been?
Old 05-07-2012, 08:34 PM   #31
Is it bad that I took one look at the first picture and knew immediately it was in NM?
dave.ruybal is offline   Reply With Quote
Old 05-07-2012, 08:46 PM   #32
Originally Posted by RGH View Post
call poco...set new pole..pole mount meter pan and panel and break out the sch 80...demo everthing else..
Even better! Good call.
3rdgenwireman is offline   Reply With Quote
Old 05-09-2012, 07:06 AM   #33
Default What tha?????????
Looks like a total restart. Rip everything out and start all over. Get cash in advance and everything in a contract on paper.
imgn.mccullars3 is offline   Reply With Quote
Old 05-09-2012, 04:19 PM   #34
magneticpersona's Avatar
i would use a mast that goes through the roof, and strap everything to the wall where the current meter base is. I cant believe a supply utility would even connect that to the grid!
For perfect electrical work at a great price!
www.absolutelyperfectelectrical.com
magneticpersona is offline   Reply With Quote
Old 05-09-2012, 06:01 PM   #35
MaxFuse's Avatar
So whats up with that second little weatherhead, whats it feeding ?
MaxFuse is offline   Reply With Quote
Old 05-20-2012, 11:36 AM   #36
Do they need the new service for the "growing" operation? HA... Ive seen worse though, but none have wanted a service upgrade. I'd go for the rigid up through the eaves...
Archania is offline   Reply With Quote
Old 05-20-2012, 11:54 AM   #37
Licensed Journeyman
nolabama's Avatar
Drive some strut in the ground and don't attach anything to the structure. Build it like a rack and wash your hands of this crack induced nightmare.
nolabama is online now   Reply With Quote
Old 05-20-2012, 01:39 PM   #38
A small nuke should address any issues.
Brian John
Leesburg, VA
The Following 2 Users Say Thank You to brian john For This Useful Post:
JDJ (05-21-2012), MIKEFLASH (05-24-2012)
Old 05-31-2012, 07:49 PM   #39
I have told many clients, "There is nothing I can do but remove everything and start over."
mikeykcl is offline   Reply With Quote
