How would you clean this up? - Electrician Talk - Professional Electrical Contractors Forum
Like Tree83Likes
Old 02-17-2017, 09:40 AM   #1
Hangry's Avatar
Rewards Points: 136
Default How would you clean this up?
Was sent a picture today from a potential client who would like a panel replacement and wiring cleaned up. how would you experts do this?
I'm really green when it comes to panel replacements on existing services.
http://imgur.com/a/uGKfd
Hangry is offline   Reply With Quote
Old 02-17-2017, 09:44 AM   #2
Hangry's Avatar
Rewards Points: 136
Cant upload file keeps failing
Old 02-17-2017, 09:45 AM   #3
NJ Contractor's Avatar
Rewards Points: 62
I would recommend to the owner an electrician with experience in the type of work he wants done. Why would you take on a project you do not know how to perform?
360max likes this.
NJ Contractor is offline   Reply With Quote
Old 02-17-2017, 09:52 AM   #4
still in business
sbrn33's Avatar
Rewards Points: 3,226
I would rip everything out put a 60 space Siemens in. That actually looks alot worse than it is. Once you get all that **** out of there it won't be so hard. You don't have your location listed so if this is in Canada nevermind because their panels are stupid.
360max likes this.
Old 02-17-2017, 09:57 AM   #5
Click Here
Rewards Points: 1,390
Personally, I don't like large panels, they get too jammed in with wires. I would rather install (2) 30 space panels than a 60 space.
I don't see any issue with this job, instal a main panel and a sub next to it and wire it up.
Old 02-17-2017, 09:59 AM   #6
Hangry's Avatar
Rewards Points: 136
Yes it is Ontario, Canada. The house is 30 years old. I was thinking to rip it all out and use 3/4 ply backer board. 200 amp 40/80 load center but wonder if I should reuse the generator panel or go with something new.
Old 02-17-2017, 10:02 AM   #7
Click Here
That's crazy using tandems in a new 40 space panel.
That's something you need to discuss with the customer. Are they ok with the limited circuits they have in the transfer panel now? Would they prefer a switch that will power the entire panel? Are they willing to pay the high cost to change it?
Old 02-17-2017, 10:03 AM   #8
Rewards Points: 9,122
Seriously, I don't see much of a mess. It might work to mount the new panel sideways. We can do that. It drives the Americans crazy .
Old 02-17-2017, 10:07 AM   #9
animal lover /rat bastard
wildleg's Avatar
the adjacent pictures on that account make me believe that this is a troll thread, so I am out.
Old 02-17-2017, 10:08 AM   #10
I use tandems all the time. Nothing wrong with them.
Old 02-17-2017, 10:10 AM   #11
Hangry's Avatar
Rewards Points: 136
What?
Old 02-17-2017, 10:15 AM   #12
Huh? He's just looking for pointers. If I didn't try anything different, I could be stuck out in the bush somewhere on a cable pull.
Old 02-17-2017, 10:16 AM   #13
What?
What he said makes no sense. Carry on.
Old 02-17-2017, 10:18 AM   #14
Deplorable-Electrician
Rewards Points: 27,846
Everyone has to start somewhere. No need to bust his balls, that cluster is bad enough on it's own.
Maple_Syrup25 and circuitman1 like this.
Old 02-17-2017, 10:21 AM   #15
If I was stuck in a bush it wouldn't be for cable pulling!
Old 02-17-2017, 10:43 AM   #16
Okay, here is how I would handle it:
First thing to consider is panel height. Your top breaker can't be higher than 1.7M. That will determine the orientation of your panel. Guaranteed your new 40/80 will be too tall if you mount it vertically like the old one. If you spin it sideways you might be okay.
I've never done it before but Hack's idea with two side by side panels could work well.
Fresh plywood is a must. You might have a little bit of grief extending your pipe in the back but all panel changes come with some grief.
4 X 4 boxes with extension rings where you need to extend branch circuits.
Old 02-17-2017, 10:45 AM   #17
Go to your room.
Old 02-17-2017, 10:47 AM   #18
Rip it all out and go from there!
HackWork likes this.
Old 02-17-2017, 11:01 AM   #19
Click Here
Putting 55 circuits into a 40 space panel in a brand-new installation is a disservice to the customer. The cost of those tandems alone will cover the cost of a second panel. You will have much more room for wiring and it will be neater.
Old 02-17-2017, 11:10 AM   #20
One tandem is cheaper (marginally) than two individual breakers. How does a second panel save money? How many callbacks have you had with tandems? I have had zero. If you don't have enough wiring space, you're filling your panels up with unnecessary wire.
Schooled.
Drsparky14 likes this.
Material to clean a flame sensor Arcflasher Residential Electrical Forum 10 06-05-2016 09:50 AM
Getting my first car, advice to keep it clean when used for work commute ? David C Tools, Equipment and New Products 27 01-24-2016 10:39 PM
