Originally Posted by Sparky480
How do you guys feel about the spray foam insulation in houses?
I don't like it. It does a good job though, I was in an attic one time that had it, it was around 95 outside and I wasn't even breaking a sweat running back and forth tracing out a few lines.
From our standpoint though, it is a PITA if you have to add or remove anything in an attic that has it. It's basically a bigger version of 'Great stuff' foam insulator. Have you ever tried to cut and remove that stuff? It's on there for good.
I've always wondered if someone wanted that stuff removed from there attic, how would you do it?
