Electrician Talk - Professional Electrical Contractors Forum (http://www.electriciantalk.com/)
-   Residential Electrical Forum (http://www.electriciantalk.com/f29/)
-   -   kitchen toe kick heater (http://www.electriciantalk.com/f29/kitchen-toe-kick-heater-63587/)
Shockdoc 12-20-2013 12:08 PM
Just a question . Does it need to be gfci protected like bathrooms. If so can it get tagged off the counter outlets
macmikeman 12-20-2013 12:13 PM
GFI requirements do not mention toe kick heaters. Why would you think that they would need to be gfi? Even a receptacle outlet down in a toe kick in the kitchen does not need to be gfi protected unless it is a kitchen in a "not" a dwelling.
Shockdoc 12-20-2013 12:17 PM
It was directly under the sink base. I thought about leaky plumbing soaking it and the floor in front of it. So I tagged it off the counter circuit.
99cents 12-20-2013 12:20 PM
374 Attachment(s)
You guys don't need dedicated circuits for kitchen counter receptacles?
MTW 12-20-2013 05:36 PM
That's technically a violation.
MTW 12-20-2013 05:37 PM
Yes, two 20-amp circuits are required for counter and dining room receptacles. There are no rules on how they can be divided up.
99cents 12-20-2013 05:49 PM
374 Attachment(s)
This makes no sense. He is concerned about GFCI protecting an illegal circuit.
BBQ 12-20-2013 06:00 PM
:blink::001_huh:
Next72969 12-20-2013 06:03 PM
Sinks are a hot topic
99cents 12-20-2013 06:12 PM
374 Attachment(s)
Originally Posted by BBQ (Post 1186179)
:blink::001_huh:
Well, he is concerned about protecting the heater in case water spills on it but he wants to connect it to a kitchen receptacle circuit, which is a violation. That makes no sense.
captkirk 12-20-2013 06:17 PM
I just installed two and I ran a dedicated line for them . I would never tap off the kit recept... if its a 120 v unit it probably draws 6 amps at the least.... I would be pissed if I was that customer and my toaster is suddenly tripping on sunday morning...
B4T 12-20-2013 06:19 PM
Only receptacles need to be GFCI protected in a bathroom or kitchen.. a kick heater is direct wired..
Vintage Sounds 12-20-2013 07:57 PM
Come on man, you're going to connect what is probably a 1.5 kW heater to a 20A receptacle circuit? Facepalm.
Dennis Alwon 12-20-2013 08:07 PM
The heater cannot be on the small appliance branch circuit. It is that simple. A kick space heater is a direct wired piece of equipment.
owl 12-20-2013 08:38 PM
Counter SA circuits can have clock outlets and chit that powers igniters/clocks for counter mounted stuff. That's about it. 210.52(B)(2)
I_get_shocked 12-20-2013 08:59 PM
Just put it on a 15a circuit in smurf tube
markore 12-20-2013 10:47 PM
What is the brand and model number of the heater? Some can be run on 220.
What about the dishwasher/fridge/disposal circuits?
If it has an optional cordest or internal protection/thermestat bay you may have more options, depending on draw; most of the ones I do are hydronic.
backstay 12-20-2013 11:09 PM
Never put the toe kick heater in the sink base. You end up burning up the misses toes. It's the one location where you must stand for long periods in place and becomes quite uncomfortable. I've had to clip elements in them to lower the heat output so the women(HO) could wash dishes.
MTW 12-20-2013 11:12 PM
Doc, are you talking about a hydronic or electric toe kick heater?
macmikeman 12-21-2013 12:11 AM
Lets all see if you can guess the one member here who has not hooked up a heater ever, even though I used to live in that extremely cold place otherwise known as Florida. I didn't even know they had "toe kick" heaters. That's kinda neat. I do know they got butt hole warmers built into toilet seats in Japan. Some of them play a tune for you also.
