kitchen toe kick heater - Electrician Talk - Professional Electrical Contractors Forum
Old 12-20-2013, 11:08 AM   #1
felonious smile.
Shockdoc's Avatar
Rewards Points: 572
Default kitchen toe kick heater
Just a question . Does it need to be gfci protected like bathrooms. If so can it get tagged off the counter outlets
Old 12-20-2013, 11:13 AM   #2
Rewards Points: 4,422
GFI requirements do not mention toe kick heaters. Why would you think that they would need to be gfi? Even a receptacle outlet down in a toe kick in the kitchen does not need to be gfi protected unless it is a kitchen in a "not" a dwelling.
It would have been impossible for us to develop our plan for the world if we had been subject to the bright lights of publicity during those years. David Rockefeller
Old 12-20-2013, 11:17 AM   #3
felonious smile.
Shockdoc's Avatar
Rewards Points: 572
It was directly under the sink base. I thought about leaky plumbing soaking it and the floor in front of it. So I tagged it off the counter circuit.
Old 12-20-2013, 11:20 AM   #4
Rewards Points: 9,970
You guys don't need dedicated circuits for kitchen counter receptacles?
Old 12-20-2013, 04:36 PM   #5
MTW
MTW's Avatar
Rewards Points: 6,775
That's technically a violation.
The Following User Says Thank You to MTW For This Useful Post:
macmikeman (12-20-2013)
Old 12-20-2013, 04:37 PM   #6
MTW
MTW's Avatar
Yes, two 20-amp circuits are required for counter and dining room receptacles. There are no rules on how they can be divided up.
Old 12-20-2013, 04:49 PM   #7
This makes no sense. He is concerned about GFCI protecting an illegal circuit.
Old 12-20-2013, 05:00 PM   #8
BBQ
Salty Member
BBQ's Avatar
Old 12-20-2013, 05:03 PM   #9
Next72969's Avatar
Rewards Points: 504
Sinks are a hot topic
Next72969 is offline   Reply With Quote
Old 12-20-2013, 05:12 PM   #10
Originally Posted by BBQ View Post
Well, he is concerned about protecting the heater in case water spills on it but he wants to connect it to a kitchen receptacle circuit, which is a violation. That makes no sense.
Old 12-20-2013, 05:17 PM   #11
Bababoee
captkirk's Avatar
Rewards Points: 2,030
I just installed two and I ran a dedicated line for them . I would never tap off the kit recept... if its a 120 v unit it probably draws 6 amps at the least.... I would be pissed if I was that customer and my toaster is suddenly tripping on sunday morning...
Full time Bovine Scatologist.
Old 12-20-2013, 05:19 PM   #12
B4T
Scotchkote Installer
B4T's Avatar
Rewards Points: 15,378
Only receptacles need to be GFCI protected in a bathroom or kitchen.. a kick heater is direct wired..
Old 12-20-2013, 06:57 PM   #13
Vintage Sounds's Avatar
Rewards Points: 3,988
Come on man, you're going to connect what is probably a 1.5 kW heater to a 20A receptacle circuit? Facepalm.
Old 12-20-2013, 07:07 PM   #14
Rewards Points: 568
The heater cannot be on the small appliance branch circuit. It is that simple. A kick space heater is a direct wired piece of equipment.
sbrn33 (12-20-2013)
Old 12-20-2013, 07:38 PM   #15
owl
Rewards Points: 250
Counter SA circuits can have clock outlets and chit that powers igniters/clocks for counter mounted stuff. That's about it. 210.52(B)(2)
owl is offline   Reply With Quote
Old 12-20-2013, 07:59 PM   #16
I_get_shocked's Avatar
Rewards Points: 516
Just put it on a 15a circuit in smurf tube
last shocked on 6/24
I_get_shocked is offline   Reply With Quote
Old 12-20-2013, 09:47 PM   #17
Thumper
markore's Avatar
Rewards Points: 530
What is the brand and model number of the heater? Some can be run on 220.
What about the dishwasher/fridge/disposal circuits?
If it has an optional cordest or internal protection/thermestat bay you may have more options, depending on draw; most of the ones I do are hydronic.
Old threads have the best patina.
markore is offline   Reply With Quote
Old 12-20-2013, 10:09 PM   #18
NRA Member
backstay's Avatar
Rewards Points: 1,996
Never put the toe kick heater in the sink base. You end up burning up the misses toes. It's the one location where you must stand for long periods in place and becomes quite uncomfortable. I've had to clip elements in them to lower the heat output so the women(HO) could wash dishes.
backstay is online now   Reply With Quote
Old 12-20-2013, 10:12 PM   #19
MTW
MTW's Avatar
Doc, are you talking about a hydronic or electric toe kick heater?
electricmanscott (12-21-2013)
Old 12-20-2013, 11:11 PM   #20
Lets all see if you can guess the one member here who has not hooked up a heater ever, even though I used to live in that extremely cold place otherwise known as Florida. I didn't even know they had "toe kick" heaters. That's kinda neat. I do know they got butt hole warmers built into toilet seats in Japan. Some of them play a tune for you also.
Next72969 (12-21-2013)
Toe Kick heater Chris1971 Residential Electrical Forum 10 04-27-2012 06:53 PM
New NFL Kick-off Rule Chris Kennedy Off Topic (Non Trade) 20 10-25-2011 08:47 PM
kick back to the GC electricmike Business, Marketing, and Sales 27 06-13-2010 09:22 PM
Box kick on short pcs of EMT subelect General Electrical Discussion 41 04-27-2010 11:39 AM
Toe Kick lighting mikeg_05 Residential Electrical Forum 17 07-13-2009 07:39 PM
