Old 05-01-2012, 04:43 PM   #1
Default Main panel ?
Meter base feeds main-breaker indoor panel directly behind it and also feeds an exterior small load center directly next to it with just (3) 2-pole breakers. My question is, can you double up wires on meter lugs? I don't think you can but can't recall ever seeing double type lugs in a meter base.
Old 05-01-2012, 04:45 PM   #2
Electrical Simpleton
Pete m.'s Avatar
I think I would be more worried first with the grouping of your service disconnects... but to answer your question it depends on the listing of the lugs. I can't recall any factory meter socket lugs that permit more than one conductor per terminal.
Pete
Confidence is the feeling you have before you understand the situation.
Old 05-01-2012, 06:14 PM   #3
976-EVIL
mcclary's electrical's Avatar
Cvec and rappahannock both supply me with 320's and 180's both with the capability of double lugging. They ask me when I get the meter base if I nneed single or double lugs
Old 05-01-2012, 06:47 PM   #4
Pete
As for this arrangement, it was existing. I don't see a code violation although it would've been nicer feeding from one panel to another versus both being treated as main panels. Im not near my book, I could be wrong.
Main lug only panel maryland General Electrical Discussion 16 01-26-2012 07:09 AM
Sub-Panel next to main panel ground. rnichols General Electrical Discussion 16 10-04-2011 05:49 AM
The panel needs a main...... jwjrw General Electrical Discussion 16 09-20-2011 09:59 PM
Main breaker panel cheaper than main lug Shockdoc General Electrical Discussion 5 07-19-2011 08:51 PM
PVC Main Panel ? Cletis General Electrical Discussion 24 06-20-2011 03:07 PM
