Old 05-01-2012, 02:37 PM   #1
Default mob home estimate
Today I did an estimate, they are replacing a trailer. I first noticed the trailer has a 100 amp main panel, the disconnect breaker is 50 amp. The feeder was 6 awg AL. Second, the garage had been fed through the main panel in the home, to a J box in the garage, which was spliced into all the circuits. The water pump was external, had 12-2 NM which was hooked onto a repair plug (yellow one with metal casing) plugged into a outlet strip. I recommended a sub panel, dedicated circuit for the pump, GFCI protected outlets, new feeders from disconnect to trailer and garage. I'll take pictures on my next trip.
Svtlightning207 is offline   Reply With Quote
Old 05-01-2012, 02:38 PM   #2
Good at being Evil
Shockdoc's Avatar
Must be in Westchester.
Old 05-02-2012, 03:50 PM   #3
Having an issue, The new home will not be within 30' of the disconnect, what is the easiest way to remedy this? thanks
Old 05-02-2012, 04:28 PM   #4
Would I be alright moving only the disconnect, I would have to run a new ground cable, some pvc, and a new post to mount it on.
Old 05-02-2012, 08:26 PM   #5
Tom45acp's Avatar
I think you're on the right track as long as the power company does not require a disconnect on the pole with the meter.
If you leave the existing disconnect in place, you would need a 4 wire feed from the pole to an additional disconnecting means. Splice & insulate the neutral at this point, use the neutral bar in the new disconnect to attach the incoming & outgoing equipment grounds, install the bonding screw or bonding jumper, pound in a couple of rods & connect, have a cold one (or two).
Sometimes I wonder whether the world is being run by smart people who are putting us on, or by imbeciles who really mean it.
Tom45acp is offline   Reply With Quote
Old 05-03-2012, 09:58 AM   #6
I talked with my inspector, he said I can just install another disconnect, with quadplex inbetween the two.
Old 05-03-2012, 05:07 PM   #7
Will a out door MLO panel with 1 double pull 100 amp breaker be acceptable as a disconnect??
Old 05-04-2012, 04:19 PM   #8
Here is the pump. Its 1/2 HP. No means of disconnect, Its wired with 12-3 romex. The white and black are hot, and the red is the ground.
Old 05-04-2012, 04:27 PM   #9
Fluke Skywalker
walkerj's Avatar
The little switch on the outlet strip is the disconnect.
Jason
walkerj is online now   Reply With Quote
Old 05-04-2012, 04:33 PM   #10
true or the outlet plug lol
Old 05-06-2012, 08:02 PM   #11
Can you tell me what's wrong? =)
I felt so dumb when I found out.
And yes, the ground bar should have been on the left side, but I hadn't planned on putting the main on the right. I fixed it though. And the panel was smaller than I wanted, but it got the job done, and my supplier was closed on saterday ( doh! )
Old 05-06-2012, 09:41 PM   #12
Neutral on wrong lug..
rnr electric is offline   Reply With Quote
The Following 3 Users Say Thank You to rnr electric For This Useful Post:
aDudeInPhx (05-13-2012), Magnettica (05-06-2012), Shockdoc (05-06-2012)
Old 05-06-2012, 09:58 PM   #13
Idk what I was thinking, I had bent it for the correct lug lined it up and everything, then I taped it, and connected to the hot buss.
Old 05-06-2012, 10:02 PM   #14
Yup, we have all done it (I hope anyway),I actually had a helper point it out to me. He actually thought I did it on purpose and asked why. Like I had some brilliant master plan.
Old 05-06-2012, 10:07 PM   #15
Lol, the sad part was, I was all proud of myself because we got it all done in time, so I took this picture. I turned the breaker on and my helper yelled from the main at the pole "woah! the breaker tripped!". Easy fix though lol.
Old 05-06-2012, 10:09 PM   #16
Originally Posted by Svtlightning207 View Post
Attachment 13758
Why'd you use such a small panel?
Old 05-06-2012, 10:17 PM   #17
I know I know, lol! My supplier was closed, and I asked him for the wrong panel the day before hand, It's a small garage, and there is an outdoor panel as well, so I figured worst case they can throw in a mini. It had just enough circuits to get done what needed to get done, hell before hand it was 10-3 romex ran from the house to a J box that fed all the branch circuits lol
Old 05-09-2012, 05:40 PM   #18
MaxFuse's Avatar
I dont see a bolt down kit on that breaker that is used as a main in that panel.
Maybe I'm just not seeing it in the pic or is it not required there?
A couple other (might have been existing) things I noticed;
1. whats up with the uninsulated conductors extending from the pump receptacle ?
2. wasn't there also a bare wire in the 12/3 that could have been used for the ground ?
MaxFuse is offline   Reply With Quote
Old 05-09-2012, 06:05 PM   #19
976-EVIL
mcclary's electrical's Avatar
Why didn't you use the lugs?
Old 05-09-2012, 06:08 PM   #20
whats with the curly Q feeders?
Bbsound is offline   Reply With Quote
Everyone wants an estimate. crazy electrician General Electrical Discussion 52 11-21-2011 06:45 PM
Estimate and Then Some... Little-Lectric Residential Electrical Forum 3 09-03-2011 09:50 PM
I need an estimate jwjrw General Electrical Discussion 30 08-15-2011 07:12 PM
Home Depot and the Home improvement Hack B4T General Electrical Discussion 180 12-31-2009 04:03 PM
Estimate this job with me... InPhase277 General Electrical Discussion 6 08-03-2009 09:17 PM
