The ones I have done are like you described. Each skylight had about a 20ft coil of romex attached. The last addition I did all (4) skylights were close enough together that we ran the 4 wires down into a double gang deep box at about receptacle height which got a dedicated circuit to feed it and a blank cover plate. The skylights came with remotes which I think was the only way to control them. We programed (1) remote to operate all 4. There are instructions with the units that you can program all seperately if you want. It would be no big deal to add a wall switch though. Don't know if I would wanna risk the switch getting turned off by accident and the units not being able to close if it starts raining and no one is around.
