08-25-2009, 08:46 PM
#241
Seen your member
Originally Posted by kornbln
What I meant was the crimping portion of certain linemans pliers.
Like these:
Is that listed for crimping splice caps?
To anything!
08-25-2009, 08:50 PM
#242
Probably. Certain Ideal lineman pliers with the crimping section and the Buchanan 4-way crimper are called out on the box.
08-25-2009, 08:56 PM
#243
B4T Scotchkote installer
Originally Posted by BCSparkyGirl
You boys do some nice work is all I can say. When I get home I will throw some pics up and you can let me know if I measure up..........
A French Maid outfit and wearing a tool belt with work boots would be a nice place to start
08-25-2009, 11:59 PM
#244
Hooked on toutons
Originally Posted by Yillis
Holy crap! What a house! This isn't 24 Sussex Drive in Ottawa is it?
For anyone who doesn't know, it's where the prime minister's house is.
Reason: Wouldn't let me add an emote :(
08-28-2009, 10:18 AM
#245
No no, 24 Sussex is old and falling apart. Probably K & T, too.
09-02-2009, 11:44 PM
#246
Did she care about how your grounds were made up, or whether they were twisted together? Seriously, how many HOs actually see the insides of our panels?
"60 seconds" of wasted time is just that.... wasted time. Any you don't make money on resi by counting dollars, you make money in resi counting seconds.
I don't mind making them neat, but there's an extreme here that just isn't worth the time. Would you spend another 10 minutes making sure all your recep boxes are within 1/64th of an inch in height? Or taking all the twists out of the NM that's run through the holes in the studs? I know some guys who will run all their 14s into one side of the panel, and all the 12s on the other. Why? I don't know, he's on third, and I don't give a darn.
I recall a builder who would drill the holes for his electrician. He would walk around to each stud with a tape measure, making a mark 20" AFF on the face edge of the studs. Then he would go around again with his square and transfer the mark to the side of the stud. Then... he would go back around with his tape measure and mark the center of each stud along the line that's at 20". Then, and only then, would he start drill holes. His rational: If Sparky had an absolute straight shot through the studs, he'd use less wire, and therefore be cheaper. Fine, Sparky uses $1 less NM, and Bob the Builder spends a day marking the studs.
It's like spending time waxing the car you're going to drive in the demolition derby this Saturday night. The laws of diminishing returns will come into play here.
If your drill man knows how to drill, all of your holes will be extremely close to equal, within 1/4" or so. It only takes 1.5 to 2 hours to drill out an average home...
besides I like going back to a house I wired and know where the wire is exactley and being able to tell some idiot over the phone where it is saves me time...
09-02-2009, 11:49 PM
#247
Originally Posted by steelersman
Well, I must admit I've never even seen the tool or used it for crimping sleeves, but I use dykes or linemans and I don't actually crimp it on the wires but rather crimp the excess sleeve so that it squeezes the wires together and then I twist them. I know, I know, I'm a hack, but hey like I said they aren't going to come undone, and in all reality, they don't even need the crimp or a wirenut if twisted well enough.
Some counties here make us use the 4 sided crimping tool stated the crimp was designed to be used that way...
09-03-2009, 05:55 AM
#248
Damn you're slower than tree sap on a cold winter day!
09-03-2009, 04:44 PM
#249
Hey, I have those
And......I can't believe anyone actually reads the information on a box of crimps
Listing? We don't need no stinking listing.
10-15-2009, 07:38 PM
#250
Tags
The romex tags are not UL listed!
10-15-2009, 07:46 PM
#251
WTF are you talking about?!
10-15-2009, 08:38 PM
#252
There are 250 posts on this thread - you will have to be a little more specific in what you are referring to.
Welcome to the forum.
John from Baltimore
"One day at a Time"
10-15-2009, 08:41 PM
#253
Seen your member
I'll bet he means those little piece of NM sheath you put on the hot wires in a panel to label the circuit with.
To anything!
10-15-2009, 08:46 PM
#254
Not Peter D
I like how in Canada you can get romex (NMD90 or loomex) with a blue jacket to identify it as an AFCI circuit.
10-15-2009, 08:50 PM
#255
Seen your member
C'mon Pete, you know what to do............
To anything!
10-15-2009, 08:52 PM
#256
Not Peter D
Nah, that takes too much time and effort. When you only charge $10 an hour for labor there's not much left to identify your cables, you know?
10-15-2009, 09:00 PM
#257
Seen your member
How about using these, then?
Oh, wait..... Never mind.
Hacks don't use staples. They just bend a 7-penny nail over.
To anything!
10-15-2009, 09:04 PM
#258
Not Peter D
Wow. I'm impressed. You even found a picture of a New England staple. And no, I don't use nails either. I don't fasten cables at all.
10-15-2009, 09:06 PM
#259
Seen your member
Uh, no.... I didn't 'find' a picture. I faked it.  Everybody and their uncle knows I have faked every photo in the world.
To anything!
10-16-2009, 02:37 PM
#260
haha, you can tell people who wire little 3000 sq.ft. spec homes right away...sorry should have said my average home...
Reason: really??just change it...
