Old 04-30-2012, 09:02 PM   #1
Default Pole barn
Starting a pole barn for my dad tommorow at his farm. Permit already pulled. A couple questions i need answered. The house is about 20' away from the structure. The house has a 200 amp underground service feeding a 40 circuit homeline. My plan is to set a 90 amp breaker in the homeline panel and since the panel sits on the exterior wall of where im going to be entering with pvc. I want to pvc out of the bottom of the panel with 1 1/4 thru the wall outside to a lb then run underground to the barn. I got a 90 stubbed in the floor already. 4 wire urd(size?) into the barn feeding a 100 amp QO main breaker panel. 2 ground rods. I am just stubbing out ofthe panel with 3/4" emt up to the cieling and running to all my ligts and outlets with 12-2.
What do yAll think?
psd7.3 is offline   Reply With Quote
Old 04-30-2012, 09:06 PM   #2
animal lover /rat bastard
wildleg's Avatar
sounds like a plan. good luck.
JHFWIC (04-30-2012)
Old 04-30-2012, 09:40 PM   #3
Awg-Dawg's Avatar
I'm just hoping to not end up on Electricmanscotts signature line.
Awg-Dawg is online now   Reply With Quote
Old 04-30-2012, 09:53 PM   #4
ET rocks
3xdad's Avatar
How do you go out of the bottom of the house panel to an LB? If the panel is on an exterior wall, just use a rear KO and nipple out to the LB.
What size URD will you be using inside that 1 1/4"?
"Starbucks makes you vote funny" ..macmikeman
"I'm gonna try something I call a compliment sandwich..." ..Big John
"i do love me some gutter" ..Eric
3xdad is online now   Reply With Quote
Old 04-30-2012, 09:59 PM   #5
2-2-4 sound right. And sorry the panel is located on the right of the service door so its not on the exterior wall i will be removing the drywall to pvc them exiting out the exterior walll.
Old 04-30-2012, 10:03 PM   #6
ET rocks
3xdad's Avatar
O.K. i see now how you are exiting the house panel, but 2-2-4 is wrong. Your OP said 4-wire.
Old 04-30-2012, 10:17 PM   #7
What size then? This part of the code confuses me. Do i run a 4 wire with a ground rod or run three wire with 2 ground rods?
Old 04-30-2012, 10:17 PM   #8
Electric Al
oldtimer's Avatar
What do yAll think?
I think you should hire an electrician!
I'd rather have a bottle in front of me , than a frontal lobotomy. ( Quote from Tom Waits. )
The Following User Says Thank You to oldtimer For This Useful Post:
psd7.3 (04-30-2012)
Old 04-30-2012, 10:19 PM   #9
Also the inspectors are hard here. Will i catch hell for drilling the studs in the house for my 1 1/4 pvc To get in the panel. Its a load bearing.
Old 04-30-2012, 10:21 PM   #10
Good at being Evil
Shockdoc's Avatar
#2 copper xlpe for 100 amps, should have stubbed 1 1/2" or 2" for aluminum . Use trailer quadplex 2-2-2-4 al xple, OCPD @80 amps until after inspection, upgrade to 100 amps.
Old 04-30-2012, 10:23 PM   #11
He wants to run aluminum for price. Trust me already tried talking him into copper. And old timer, all the electricians are busy here so im trying to find a plumber haaha
Old 04-30-2012, 10:28 PM   #12
ET rocks
3xdad's Avatar
Check out 250.32 250.50 and 250.52.
Old 04-30-2012, 10:35 PM   #13
wendon's Avatar
Where are you mounting the panel in the barn? What is the barn going to be used for? Like has already been stated, I'd recommend a 2-2-2 URD with and additional USE #4 4th wire. If cattle are housed in the pole barn that changes the whole picture.
Ive seen burnt up outlets, chard neutrals, and shorted wires.
Uncfesta
Old 04-30-2012, 10:36 PM   #14
No animals. All for storage
Old 04-30-2012, 10:37 PM   #15
Panel is on exterior wall next to service door
Old 04-30-2012, 10:56 PM   #16
wendon's Avatar
Should be no problem then but you'll have to make sure the URD is dual-rated. 2-2-2 URD dual-rated with an additional 4th USE wire no smaller than #6. Problem you got is your PVC is too small for that!! Upsize to 1½" PVC or larger! Two ground rods installed at the barn service. Call before you dig!!! No electricians in Ohio???? Hard to believe
Uncfesta
The Following User Says Thank You to wendon For This Useful Post:
mcclary's electrical (05-01-2012)
Old 05-01-2012, 08:42 PM   #17
I'd recommend doing a 2" conduit, cost won't be too horrible, as its only ~20', and it will be a hell of a lot easier getting 3 2 awg & a 4 awg through the LBs.
Svtlightning207 is offline   Reply With Quote
Old 05-01-2012, 09:17 PM   #18
ampman's Avatar
oh---yes unless you have 8x8s on 4" centers
"There are two ways to conquer and enslave a nation ...one is by sword...the other is by debt" John Adams 1826
ampman is offline   Reply With Quote
Old 05-01-2012, 10:38 PM   #19
I guess my only real question is if i could get away with 3 wire urd ( ive got 100 foot of it at our shop the boss said i could have) instead of using 4 wire. Since it would be considered a seperate service right? Having a hard time finding this in my 08 book
Old 05-01-2012, 10:47 PM   #20
Heavily Armed Member
HARRY304E's Avatar
The panel in the barn is a sub panel so you will need to run 4 wire.
Temporarily replacing 4-pole transfer switch with 3-pole erics37 General Electrical Discussion 34 03-04-2012 10:57 PM
Wiring a residential pole barn, can you use NM? nitro71 NEC Code Forum 18 02-20-2011 11:45 PM
cow barn luminaires Ranger2001 General Electrical Discussion 16 02-16-2011 02:09 AM
gfi in a barn roach1521 General Electrical Discussion 15 09-03-2009 09:43 PM
Horse Barn jbfan General Electrical Discussion 4 01-25-2007 10:40 PM
