Old 04-30-2012, 07:52 AM   #1
Default pvc grounding question
I,m installing a 34 KW Kohler generator with a 2 inch schedule 89 underground feed that stubs up thru the concrete pad. The nuetral in the transfer switch is not switched so the unit does not require a ground but do i still have to ground the case? I,m pulling 1/0 thhn do i need another green 1/0 or will a # 4 suffice? I always use galvanized and am not familiar with grounding sizes with pvc
greenlee is offline   Reply With Quote
Old 04-30-2012, 07:58 AM   #2
Electrical Simpleton
Pete m.'s Avatar
It will depend on the size of the OCPD in the genset. See 250.122 and table 250.122
Pete
Confidence is the feeling you have before you understand the situation.
Grounding Question dronai General Electrical Discussion 9 10-28-2011 01:00 AM
Grounding Question johnnyontheside General Electrical Discussion 2 10-21-2011 09:31 AM
Grounding Question???? schollsds General Electrical Discussion 1 10-14-2010 12:04 AM
grounding question ianis General Electrical Discussion 18 04-08-2010 05:46 PM
Grounding question businmike NEC Code Forum 2 05-31-2008 09:05 AM
