Old 11-01-2009, 02:17 PM   #1
Member Liuna local 689
ryanapplequist's Avatar
Default question for the pros
what is the code for the distance of a disconnect for a water heater ?
ryanapplequist is offline   Reply With Quote
Old 11-01-2009, 02:23 PM   #2
Within sight of and not more than 50 feet
If u see kay tell her I want her.
Old 11-01-2009, 02:29 PM   #3
Ratus Maximumus
Bob Badger's Avatar
I agree but will add a breaker lockout device installed at the panel could do it as well.
Bob Badger
Electrical Construction and Maintenance
MA, RI, CT
Old 11-01-2009, 02:31 PM   #4
Ratus Maximumus
Bob Badger's Avatar
By the way, Dennis and I where talking NEC rules.
If this happened to be an oil fired water heater the mechanical code would likely want a switch on the unit that can be reached while servicing the unit.
Bob Badger
MA, RI, CT
Old 11-01-2009, 04:21 PM   #5
Robotic Rat
nolabama's Avatar
hey ryan glad you found this site - hope the job hunt is going well
the more i learn the less i know
Old 11-02-2009, 02:48 AM   #6
well lets just say its going
Old 11-02-2009, 01:58 PM   #7
Toronto Sparky's Avatar
Funny.. I just removed my tank from flat rate and put it into the panel ,and being that I could not find anything in the code book I called the inspection dept and ask them about location of disconnect.
They told me disconnect is not required and the breaker was OK for that purpose regardless if the panel was within site.
Sure that only applys to residential.
BTW it passed..
Don't fight .. Play nice!
Old 11-02-2009, 02:16 PM   #8
thanks guys i was wondering cuz a few months back i was on a job where we put up the disconnects and wired them and when we came back to wire up the water heaters the plumbers had the dam things right up on the d/c's never found out what happened i leaft the job a week later due to problems with pay
Old 11-02-2009, 04:25 PM   #9
Default Electric heater
Where is the code requirement for the disconnect/circuit breaker in the code book regarding electic water heaters?
RIVETER is online now   Reply With Quote
Old 11-02-2009, 06:35 PM   #10
Rat Bastard
NolaTigaBait's Avatar
Old 11-03-2009, 04:19 PM   #11
Master Electrician
rewire's Avatar
We have alot of vacation homes and when they winterize they like a disconnect right at the HWH so the don't cook the elements
rewire is offline   Reply With Quote
Old 11-03-2009, 04:24 PM   #12
Default Electric water heaters
I can understand that one...My son keeps going to the cabin during the winter months and forgets to NOT turn the breaker on before it fills up. I wonder if anyone makes one with a float switch.
Old 11-03-2009, 05:52 PM   #13
Master Electrician
rewire's Avatar
I thought about a pressure switch and a shunt trip breaker so if you lost water pressure in the tank the breaker would shut off
What are the Pros and Cons of being a Union Electrical Contractor? BeldenElectric Union Topics 3 09-01-2009 11:53 AM
pros and cons of T5ho retrofits Vs Mh fixtures personal Lighting Design 18 08-28-2009 04:37 PM
yes im a newbie need help from pros naterosebuffalony General Electrical Discussion 1 03-08-2009 08:45 PM
Help from the pros needed!!! davidaduhon21 General Electrical Discussion 20 03-02-2009 01:42 AM
