removing the meter tamper tag - Electrician Talk - Professional Electrical Contractors Forum
Closed Thread
Old 06-18-2010, 11:00 AM   #1
Rewards Points: 107
Default removing the meter tamper tag
Fellas, so hypothetically speaking, if a customer doesnt want a heavy up just a new panel installed, and "someone" was to just go ahead cut the tag, pull the meter and replace the panel. Anyone have any bad experiences or advice to this subject. Oh and reason for not wanting to pull a permit... Owner has a ton of work going on without OF COURSE a building permit and is scared of a inspector coming in and shutting him down.
Thanks guys. Hope everyones doing well out there.
P.S. the replies to the "price quotes" questions are HILARIOUS!!
Power21 is offline
Old 06-18-2010, 11:03 AM   #2
evil bastard
mcclary's electrical's Avatar
Rewards Points: 746
Around here, there's one power company that monitors that through signals. Unplug the meter, and they show up about 20 minutes later. Better be a quick service change.
mcclary's electrical is offline
Old 06-18-2010, 01:06 PM   #3
Rewards Points: 150
Old boss used to use the "had to do emergency power down" excuse.
Why that would involve pulling the meter is beyond me, he also had us do our own hookups so...
Geoff C is offline
Old 06-18-2010, 01:17 PM   #4
animal lover /rat bastard
wildleg's Avatar
Rewards Points: 384
it's your neck. do what you want.
wildleg is offline
Old 06-18-2010, 02:11 PM   #5
Hypothetically speaking, I wouldn't do it with a digital meter. but if I did, I think it would be proper to make a call to the metering div to let them know that they need to apply another tag.
No inspector, they don't need to know why you had to shut it down.
But that is here,, not there. Don't know your area.
my theory of course.
JohnR is offline
The Following User Says Thank You to JohnR For This Useful Post:
psd7.3 (09-22-2012)
Old 06-18-2010, 02:39 PM   #6
Toronto Sparky's Avatar
Rewards Points: 1,008
Smart meters will send signal (or more like NOT send a signal) within the hour and they will know there is no power at your meter.. The only way to get around it is to wait for a power failure in the neighbourhood before you pull meter and hope it stays off for a while.. Personally.. I would get a permit.. Just think about all those guys that installed FPE panels and had the house catch fire. (Installer almost always gets blamed first)
Don't fight .. Play nice!
Toronto Sparky is offline
Old 06-18-2010, 04:45 PM   #7
Rewards Points: 107
Default Thanks guys
hmmmm... I def never thought about a disconnected meter sending (or not sending!) a signal. Good looking out fellas. I decided to pull a permit and just wait a while until all the work inside the house is completed to call for a final.
Power21 is offline
Old 06-18-2010, 08:13 PM   #8
Ambassador of Amps
TOOL_5150's Avatar
Rewards Points: 2,126
Good call... I would always do a service change with a permit - its your ass on the line. I guess PG&E could care less if the meter has power or not, I did a service upgrade with a digital meter about 2 weeks ago, Pulled it and replaced the main breaker enclosure and noone showed up.
~Matt
TOOL_5150 is offline
Old 06-18-2010, 09:06 PM   #9
Rewards Points: 1,288
I cut seals as necessary, I DO NOT SUGGEST OTHERS DO THIS, in my area it has never been a big issue (or at least overlooked), I often see meters and CT cabinets without seals. I know different utilities take this very serious.
Lately two utilities in our area have gone to padlocks.
brian john is offline
Old 06-18-2010, 09:16 PM   #10
I own stock in FotoMat!
Rewards Points: 6,520
I'm fortunate enough to have a lineman friend. He supplies me with extra tamper locks. So whenever I need to pull a meter, I can relock it w/o the POCO having to worry about it.
480sparky is offline
The Following 3 Users Say Thank You to 480sparky For This Useful Post:
AAE805 (09-18-2012), HARRY304E (09-17-2012), RGH (09-17-2012)
Old 06-18-2010, 09:21 PM   #11
kbsparky's Avatar
Rewards Points: 1,000
We have several utilities in this area. One of them gets real anal if you cut a seal/pull a meter. Sometimes takes days to get an appointment for them to do it.
The other one says if you're a licensed electrician, you have the authority to do it, just call `em and let `em know so they can reseal it later.
-KB
kbsparky is offline
Old 06-18-2010, 09:47 PM   #12
Buck Parrish's Avatar
Rewards Points: 188
Originally Posted by kbsparky;
We have several utilities in this area. One of them gets real anal if you cut a seal/pull a meter. Sometimes takes days to The other one says if you're a licensed electrician, you have the authority to do it, just call `em and let `em know so they can reseal it later.
That's how it is in our aea.
If your licensed and expierienced some times you need to pull the meter to see if the problem is on the utilities side or in the building.
Nobody read me my rights!
Buck Parrish is offline
Old 06-18-2010, 11:02 PM   #13
Rewards Points: 628
I am pretty much the same thing with 480sparky as well I have few extra meter seal with me but the only one I will not touch is red meter seal that I will have to talk to POCO first due some customer did not pay the bill or other issue going on.
Simauir to France as well but I keep Red/White tag as well for lockout on the fuse cutoff point on the post.
Merci.
Marc
frenchelectrican is offline
Old 06-18-2010, 11:28 PM   #14
Bkessler's Avatar
Rewards Points: 2,000
I've twice had people who didn't want permits get "caught", both in the same city. Anaheim, they own their own utility and their meter readers will rat you out. Once a little old lady had to get permits, and pay a small fine. One guy told them to f off, and dared them to shut off his power after they threatened to, they went away.
When ls lunch?
Bkessler is offline
Old 06-19-2010, 05:53 AM   #15
Jesus Scott
electricmanscott's Avatar
Rewards Points: 232
Same here. I have never had a problem.
Life is hard
electricmanscott is offline
Old 06-19-2010, 10:35 AM   #16
Fried Bologna um um good!
jwjrw's Avatar
Our poco has never gave me any problem about pulling meters. I do it all the time. Permit or not. Like 480 said what if you have to check the neutral in the meter can on the load side? You could pull a smart meter here and poco wouldn't show up till you called them for a no power complaint.
jwjrw is offline
Old 06-19-2010, 10:42 AM   #17
den
den's Avatar
Rewards Points: 250
Not a problem here. I have extra seals for some meters but will usually call just to get the ok. Our digital meters will record an outage but the poco doesnt download them for around 2 weeks at a time so that is a non-issue. Just don't break the seal on the meter glass!!
Old retired lineman turned electrician!
den is offline
Old 06-20-2010, 07:08 PM   #18
felonious smile.
Shockdoc's Avatar
Rewards Points: 572
pulling meters and tags??? Ive got a job thats been sitting two months now with triplex feeding directly into the panel while the stucco guys do their thing. Thank god its been a cash transaction with no paper work...
Shockdoc is offline
Old 06-21-2010, 04:51 PM   #19
MarkyMark's Avatar
In the Progress Energy service requirements manual, it says...
"When a licensed electrical contractor removes a Company Seal, said contractor shall replace the seal with a tie wrap type with a tab displaying the contractor's name and contact number, and the contractor shall notify the Company in a timely manner."
...but I have never heard of anyone actually doing any of that. Duke Energy has similar wording in their manual, and I have never seen anybody do anything other than put the cut tag back on.
MarkyMark is offline
Old 06-21-2010, 05:19 PM   #20
wildleg's Avatar
Rewards Points: 384
we have a couple pocos that are very particular about tags (especially on CT cabinets)
wildleg is offline
Closed Thread
Tamper Resistant Receptacles Roger123 General Electrical Discussion 59 02-15-2010 05:54 PM
tamper resistant plugs zen Residential Electrical Forum 34 01-18-2010 05:15 PM
Removing an old box. boots 211 Residential Electrical Forum 32 11-24-2009 06:36 PM
Question about removing a screw type fuse box... OmegaBunny General Electrical Discussion 3 09-15-2008 06:48 PM
Tamper-resistant receps... waco General Electrical Discussion 2 05-21-2008 08:25 PM
