Old 11-18-2009, 08:58 PM   #21
Site Idiot Smacker
BCSparkyGirl's Avatar
Originally Posted by BuzzKill View Post
This guy cracks me up...I'm starting to like his input, however irrelevant it is.
it's his tinfoil hat.....he can tune in the comedy channel from sat radio stations........
Don't make me bust out the apprentice stick!
BCSparkyGirl is offline   Reply With Quote
Old 11-18-2009, 09:09 PM   #22
Unlimited Lic.Electrician
william1978's Avatar
Originally Posted by sparks134 View Post
Why is there a 3way in a bedroom to control a light in the hallway?
Why does this bother you? I have a switch in my bedroom that controls 3 rec in the soffit outside for Christmas lights. (May I add that there is not one extension cord used.)
william1978 is online now   Reply With Quote
Old 11-18-2009, 09:15 PM   #23
bored member
BuzzKill's Avatar
his use of exclamation points! gets! kinda! annoying!! though!!! He could be our pet, the green helper you abuse on a daily basis...needs a name though, I'm tempted to rip Chelsea Lately's nickname for the midget on her show, "Nugget" but we casn always use "dumbass" I guess.
Old 11-18-2009, 10:03 PM   #24
captkirk's Avatar
Originally Posted by NolaTigaBait View Post
Like the others have said, I'd use a dremel or a sawzall. I've used a sawzall with a new metal blade. Be careful and take your time.
thats what I would and have done as well. Let the blade do the work, dont put to much if any pressure on it and make sure it is a brand new blade. Other times if the wall seems sturdy enough I will break the box down a bit by prying its side off, this helps limit any damage when you sawzauwl it. Good luck.
Old 11-18-2009, 10:04 PM   #25
Site Idiot Smacker
I think "twitly" has a much cuter ring to it.
Old 11-18-2009, 10:08 PM   #26
rdr
rdr's Avatar
How about "Speed Lunker"? That just screams efficient dumbass.
rdr is offline   Reply With Quote
Old 11-19-2009, 04:54 PM   #27
Jobless Extraordinaire
Grimlock's Avatar
If I don't have a power tool to do the job I used something like this:
(It's a handle that accepts sawzall blades, use a metal cutting blade)
*Ignore the second image, mine does not have a screw driver attachment
Grimlock is offline   Reply With Quote
Old 11-19-2009, 04:57 PM   #28
Licensed Journeyman
nolabama's Avatar
Something I just thought of while whittling away at 1000 posts you can use a oxy acetalyn torch and a fire exingusher
Old 11-19-2009, 05:08 PM   #29
Grimlock's Avatar
Why not just use dynamite?
You can even train fido and fluffy to deliver...
Old 11-19-2009, 05:55 PM   #30
If you have an extra hand, have them hold the box tightly wit sidecurrers while you sawzall it off.
If the plaster breakes off it only take a few minutes to patch it.....unless it's wallpapered.
220/221 is online now   Reply With Quote
Old 11-19-2009, 07:41 PM   #31
bored member
BuzzKill's Avatar
Tried that by myself with limited results, the sawzall in left hand, kliens in the right..key is to take your time.
Old 11-21-2009, 09:37 AM   #32
JohnJ0906's Avatar
I think the key to any work involving old plaster is taking your time. Rushing will only cause damage.
John from Baltimore
"One day at a Time"
Old 11-24-2009, 06:36 PM   #33
AllStar's Avatar
Just use a double stack 3-way switch and leave the existing box.
It is what it is!!!
AllStar is offline   Reply With Quote
Question about removing a screw type fuse box... OmegaBunny General Electrical Discussion 3 09-15-2008 06:48 PM
