Old 11-05-2009, 07:08 PM   #1
MAKALUA09's Avatar
Default Residential code q?
Is there any violation for using a 100a subpanel as a 60a subpanel? I've looked in the 2008 and have yet to find anything? Your thoughts are greatly appreciated.
SLOWLY yet SURELY
MAKALUA09 is offline   Reply With Quote
Old 11-05-2009, 07:09 PM   #2
child please.....
NolaTigaBait's Avatar
Nope.
Old 11-05-2009, 07:10 PM   #3
not that I Know of.
Sparky480 is offline   Reply With Quote
Old 11-05-2009, 07:11 PM   #4
MAKALUA09's Avatar
thanks guys!
SLOWLY yet SURELY
Old 11-05-2009, 07:21 PM   #5
Unlimited Lic.Electrician
william1978's Avatar
What is the connected load? As long as it isn't over 60a then there is no problem.
Old 11-05-2009, 07:25 PM   #6
MAKALUA09's Avatar
Im gonna be feeding the kitchen with this subpanel. I'm gonna be putting a 60a breaker on it so i'm hoping the inspector doesnt say " what if the HO decides to add more circuits because the panel would have more room".
My thing is if its being protected by a 60a breaker the wire should be protected no matter how much it draws. If everything were to be on at the same time then Im assuming the breaker would do its job.
SLOWLY yet SURELY
Old 11-05-2009, 07:28 PM   #7
The inspector is there to inspect not suspect.
Old 11-05-2009, 07:29 PM   #8
MAKALUA09's Avatar
guess im just overthinking it.
SLOWLY yet SURELY
Old 11-05-2009, 07:32 PM   #9
No. Had a inspector tell me once that he doesn't care what they plan on doing latter on he only wanted to look at what was installed at this point.
Old 11-05-2009, 07:35 PM   #10
Seen your member
Or expect.
Old 11-05-2009, 07:37 PM   #11
Or expect.
I would like fries with that please.
Old 11-05-2009, 07:38 PM   #12
MAKALUA09's Avatar
I appreciate it guys! Have a good one
SLOWLY yet SURELY
Old 11-05-2009, 07:38 PM   #13
Seen your member
Sorry pal, we're cleaning the grease fryer right now. We don't have any fries today so how about picking something else?
YouTube Video
ERROR: If you can see this, then YouTube is down or you don't have Flash installed.
Old 11-05-2009, 07:40 PM   #14
Default 100 amp sub-panel
I am just throwing this out there; I have not done residential in a long time. Let's say the kitchen would now, or in the future have a range with a self cleaning oven. HIGH draw. Let's say that it is thanksgiving and the oven, and all of the surface burners are in use. Now add a microwave and a couple of warming trays and a crockpot ,or two. That is the way it is here on T-day. What would be the current draw? And since it would be on presumably, more than two hours. What size sub panel should it be?
What size feeder, as well?
Old 11-05-2009, 07:41 PM   #15
MAKALUA09's Avatar
Lmao 480
SLOWLY yet SURELY
Old 11-05-2009, 07:44 PM   #16
Seen your member
That would be the sole responsibility of the person (hopefully a qualified electrician) to determine at the time.
There's just no way you can plan for the future. If you wanted to size the panel for a future range, why not size it just in case someone wants to add a hot tub outside? And a whirlypool in the master bath? And then stick a double-broiling oven next to the range? And a Viking fridge & freezer pair?..................
Old 11-05-2009, 08:00 PM   #17
child please.....
Yeah, just install a 400 amp subpanel.
Old 11-05-2009, 08:00 PM   #18
Licensed Pro
Magnettica's Avatar
What if the guy wants an arc welder installed on the countertop instead of a microwave?
Vince Lombardi
Old 11-05-2009, 08:01 PM   #19
child please.....
Old 11-05-2009, 08:04 PM   #20
You welcome, You too.
SunPower/FPE hybrid (code? what code?) lbwireman NEC Code Forum 6 08-12-2009 09:27 PM
lv in residential te12co2w Other Codes and Standards 4 02-04-2009 03:03 PM
lv in residential te12co2w Structured Wiring 3 02-04-2009 09:43 AM
2008 residential code changes Xknob&Tube NEC Code Forum 26 08-24-2008 07:12 AM
National Electrical Code: Analysis & Explanation of the Underwriters' Electrical Code Joe Tedesco Vintage Electrical 3 12-28-2007 11:47 PM
