Closed Thread
Old 02-27-2009, 01:35 PM   #1
Question Running wire from meter to panel
Hi,I am building my own home and I am at the half way point in my electrician course so I am going to wire most of my house myself but before i start i need to know:
The room where i want to place the breaker panel is 20 feet from where the meter will be,My house has no basement but is built on cement slab and raised off it 3 feet by cement blocks.
Can I run the wire from the meter under the house and up through the flooor in the panel room to the panel box?
If i can do i need to run it in conduit??
I am in canada.
Also what is the wire called?And what size is it?
3? 03?003?
cutter34 is offline
Old 02-27-2009, 01:41 PM   #2
Sorry to say,but based on the questionand you being Half way through training.
Your half part of wiring your house should be watching a pro.
No disrespect intended.
leland is offline
Old 02-27-2009, 03:24 PM   #3
"A" inside wireman
randomkiller's Avatar
If your telling me that you have over two years in apprenticship, you must be sleeping in class. Call a pro to wire your house, the life you save maybe your own.
"One Nation Under God"
randomkiller is offline
Old 02-27-2009, 03:40 PM   #4
Chief Electron Relocator
Call an electrician. He'll know what to do......
480sparky is offline
Closed Thread
320A meter, 200A meter, disc grouped? Marcopolo General Electrical Discussion 3 02-18-2009 10:26 PM
Running Low voltage wire across a Commercial rooftop ScottyK General Electrical Discussion 12 12-07-2008 09:49 PM
Meter panel question Michaeljp86 General Electrical Discussion 32 11-20-2008 12:11 AM
running cable Russell UK Electrical Forum 2 10-12-2007 03:36 PM
