Old 06-29-2009, 05:34 PM   #1
Default Service disconnect - 400A residential
Doing the typical 400A nom 320A cont residential service feeding 2-200A main lug panels. Outside disconnect is required. Usually we spec out Siemens or Square D meter main with 2-200A main breakers to feed the load panels which are distributed inside the house.
Well, I just got the quote from our supply house for the Siemens meter main at more than $3k, Square D is higher. That won't fly.
So, I am looking for a separate 4 or 6 slot service disconnect rated at 400A to mount adjacent to the meter socket. Looking through the catalogs at the supply house, we can't seem to find anything that will work.
Anybody use this setup? Who's disconnect do you use?
Vermaraj is offline   Reply With Quote
Old 06-29-2009, 05:47 PM   #2
I usually just use 2-200 amp Midwest disconnects. Any reason why you have to have 1-400 as opposed to 2-200's?
Jim
wirenut1110 is offline   Reply With Quote
Old 06-29-2009, 05:58 PM   #3
Gosh I believe we pay less than $500.00 for a Cutler Hammer combo panel 400 amp Single Phase. Heck I'll sell it to you for $1,000 and you pay the shipping.
Old 06-29-2009, 05:59 PM   #4
NYC and you have a 400 amp service on a residence? Wow, everything is gas there.
Old 06-29-2009, 07:29 PM   #5
Spec that meter-main in Milbank and see what kind of price they come back with.
Old 06-29-2009, 07:37 PM   #6
Originally Posted by mdshunk View Post
spec that meter-main in milbank and see what kind of price they come back with.
$1300.
Old 06-29-2009, 08:10 PM   #7
Can't Remember
Or try Durham
Old 06-29-2009, 08:33 PM   #8
Residential?
I can buy a 400 amp 40 space meter/main(s) at The Home Depot for about $500. Seimans, Gutler Hammer or Homeline One 200 amp breaker for the 40 space bus and one 200 amp breaker for an additional panel that you put wherever you like.
Commercial?
We have two local manufacturers that will build a can with the meter socket and two 200 amp pullouts for about $800. Probably less now
I see it's resi.
Just run half your circuits outside to the 40 spaces available (AZ style) and put a second panel inside for the other half.
Old 06-29-2009, 08:35 PM   #9
Originally Posted by 220/221 View Post
Residential?
Gutler Hammer? Sounds painful.
Old 06-29-2009, 08:36 PM   #10
A 200 amp pullout? Does that require a come-along to remove it and a rubber hammer to put it back in?
Old 06-29-2009, 08:37 PM   #11
Residential?
Lucky you. A Milbank 400 amp meter main with two-200 amp disconnects does indeed cost $1300.
Old 06-29-2009, 08:37 PM   #12
Chief Electron Relocator
Jes' use a rope and your bumper.
Old 06-29-2009, 08:40 PM   #13
Don't you guys own forearms?
The pullouts are not much bigger than a 60 amp pullout. They use JJN fuses about 2" long.
Old 06-29-2009, 08:43 PM   #14
child please.....
NolaTigaBait's Avatar
Residential?
Commercial?
I see it's resi.
The Home Depot here doesn't stock anything over 200 amps...That would be interesting if they did.
Old 06-29-2009, 08:43 PM   #15
Don't you guys own forearms?........
Sure we do!
Oh, you said forearms! Sorry!
Old 06-29-2009, 08:44 PM   #16
I didn't click.
I was afraid you were going to say foreskins.
Old 06-29-2009, 08:47 PM   #17
I didn't click.
But you can hover.........
Old 06-29-2009, 08:52 PM   #18
I remember now. Square D used to make a QO panel that had a main pullout instead of a breaker to get the 22K interrupt rating. You're right... it's not much bigger than a range pullout in the old fuse panels. I forgot.
Old 06-30-2009, 02:37 PM   #19
PGW Professional
Magnettica's Avatar
Why not use a 320 amp meter pan with double lugs on the load side and put in 2-200 MB panels instead?
Or do the disco's need to be located outside?
Old 07-04-2009, 05:31 PM   #20
Larry Fine's Avatar
Send a message via AIM to Larry Fine
Residential?
Or a 200a ATS.
I laid in bed last night, looking up at the stars, and
I said to myself, "Where the hell is my ceiling?!"
Larry Fine, Master Electrician and
Electrical Contractor, Richmond, Va
Larry Fine is offline   Reply With Quote
remote disconnect of service using solid state contactors? gehadi Services and Service Equipment 0 06-01-2009 04:39 PM
Locks on Main Service Disconnect. pudge565 NEC Code Forum 2 07-29-2008 11:38 PM
service disconnect location? electromanj Services and Service Equipment 15 06-07-2008 05:09 PM
Residential 400a. Service Both Main Tripping Karpo1961 Services and Service Equipment 3 04-08-2008 11:14 PM
Clearance for a service disconnect joleesparkey Services and Service Equipment 1 03-11-2008 03:21 PM
