Old 07-04-2009, 06:33 PM   #21
Larry Fine's Avatar
Send a message via AIM to Larry Fine
Originally Posted by Magnettica View Post
Why not use a 320 amp meter pan with double lugs on the load side and put in 2-200 MB panels instead?
That's what I do, since we're lucky enough to receive meter bases free from the POCO.
I laid in bed last night, looking up at the stars, and
I said to myself, "Where the hell is my ceiling?!"
Larry Fine, Master Electrician and
Electrical Contractor, Richmond, Va
Larry Fine is offline   Reply With Quote
Old 07-07-2009, 03:48 PM   #22
Inspector was busting our &&** on this job.
Outside disco is required. Inspector wanted a single disconnect which is not required by any POCO or local building codes. That narrows the number of available panels significantly.
After sitting down with inspector and his supervisor, and his supervisor we were able to agree on a basic meter combo with 2-200 amp mains and 8 slots.
By the way this service is for the guest house. The new guest pool and guest pool house were two much for the 200A service.
NYC encompasses several boroughs, including a large portion of Long Island. Many more single family houses than multifamilies in Manhattan (NYC proper).
Vermaraj is offline   Reply With Quote
Old 09-11-2009, 10:19 PM   #23
we just mount the 400 amp with offsets to 2 200 amp exterior disconnects, one on either side and then into the house with 2 runs of service cable to 2 200 amp panels..
the can is mil-bank and the disconnects are Square D...
Lythropus is offline   Reply With Quote
Old 09-11-2009, 11:12 PM   #24
That's my normal method too. I have to pay about a bajillion dollars for a 400 amp meter can with built-in 200 amp disconnects.
remote disconnect of service using solid state contactors? gehadi Services and Service Equipment 0 06-01-2009 05:39 PM
Locks on Main Service Disconnect. pudge565 NEC Code Forum 2 07-30-2008 12:38 AM
service disconnect location? electromanj Services and Service Equipment 15 06-07-2008 06:09 PM
Residential 400a. Service Both Main Tripping Karpo1961 Services and Service Equipment 3 04-09-2008 12:14 AM
Clearance for a service disconnect joleesparkey Services and Service Equipment 1 03-11-2008 04:21 PM
