Old 04-28-2011, 09:09 AM   #1
Default Service entrance conductors: one aluminum & one copper
Looked at a house and found a 4/0 aluminum entrance cable on one main panel lug and one 2/0 copper cable on the other. 200 amp breaker so, in theory that should be alright but can you mix like this?
68 Malibu 383 is offline   Reply With Quote
Old 04-28-2011, 09:14 AM   #2
As long as it isn't parallel conductors it should be compliant.
Old 04-28-2011, 10:13 AM   #3
Cletis's Avatar
Default ??
Not sure what that means? Can you re-explain or is it just me?
Old 04-28-2011, 10:16 AM   #4
I am saying that you can mix aluminum conductor with copper conductors as service entrance or feeders. However if there is a parallel run that you must abide by 310.4(B). The conductors in this case must be the same material as well as other restrictions.
Old 04-28-2011, 10:54 AM   #5
Cletis's Avatar
Default OP
Sorry, I meant the OP. I don't know exactly what the question is. 1 seu service cable with a 4/0 Al and a 2/0Cu in the one cable or 1 service cable with one conductor in one panel and one in another or something else?
Thanks for the code ref though..
Old 04-28-2011, 11:14 AM   #6
I think it is conduit with one copper conductor and one aluminum conductor. At least that is my take.
Old 04-28-2011, 07:56 PM   #7
Yes, that is correct. Thanks for your help. Guess they had a remnant to get rid of.
Old 10-16-2011, 01:27 PM   #8
don't any idea why someone would do that but guess i've seen worse but at least change the 2\0 cu to 3/0.
RAHARRIS78 is offline   Reply With Quote
Aluminum Conductors janagyjr General Electrical Discussion 21 02-16-2011 07:41 PM
Copper tied to aluminum sparks134 General Electrical Discussion 23 01-29-2011 02:43 PM
Service Entrance Conductors Tap Rule aksparky General Electrical Discussion 13 09-17-2010 03:51 PM
Aluminum vs Copper and 12 2 vs 14 ahring1 General Electrical Discussion 21 09-13-2010 10:04 PM
Service Entrance Conductors Absolutetruthz Services and Service Equipment 15 06-08-2008 03:16 PM
