Originally Posted by BryanMD
Being an electrician...
I'd suggest you push for the "move the electric" option.
Let the plumbers find their own work.
Know what I mean Vern?
I agree with BryanMD, push the electric move. The extra cost for the customer should be the same. Put the money in your pocket and screw the plumber. Tell the customer it will get it done faster if you move the service since your there already.
Wisconsin is 3'. I don't think it's in the NEC, it's in the building code??? Not sure on that one, just know 3' is a fact.
Also,, check your local code to see what the requirement is for the lenght of the service conductors. WI is 8' at the piont of enterance to the panel max or you need to put a service disconnect on the outside of the building next to the meter. Then the panel becomes a sub (or main lug).
