Service mast. - Electrician Talk - Professional Electrical Contractors Forum
Old 04-29-2010, 03:29 PM   #1
Default Service mast.
I have been hired to upgrade a service that has a mast, something I have never done, although it does not seem that difficult, my only issue is the power company wants me to put a guy wire on it. The mast will stick above the roof line approx. 36" with the service drop attached to the mast. I have never used a guy wire before and I am having trouble locating one, is this something that is bought as a "kit" or something I have to piece together? Any advice would be appreciated .
rookie67 is offline   Reply With Quote
The Following User Says Thank You to rookie67 For This Useful Post:
Tom12K (08-29-2016)
Old 04-29-2010, 03:36 PM   #2
Rewards Points: 5,198
It has been a long time since I've put a service in but it used to be that I'd run the 2" riser up and place a messenger cable clamp for them to use. A guy wire indicates that you are using wire to hold the mast up. You could use a couple of pipe clamps with wood auger-type threads through the framing. and that would be pretty sturdy.
Old 04-29-2010, 05:55 PM   #3
I own stock in FotoMat!
Rewards Points: 6,520
What you are asking about is governed by your local POCO rules, not the NEC. Your first call should be to them.
Old 04-29-2010, 06:33 PM   #4
Right, according to 230.24 exception 3. I don't even need to change the mast, but POCO wants guy wires, I have never used them and and I am not sure where to get them or if I have to make my own.
Old 04-29-2010, 06:35 PM   #5
child please.....
NolaTigaBait's Avatar
Rewards Points: 14
They want it guyed no matter what?...or if you go over a certain height?
Old 04-29-2010, 06:37 PM   #6
This is what the POCO referred me to, http://www.nationalgridus.com/non_ht...on_greenbk.pdf page 113. It doesn't explain much, the mast height he said needs to be at least 36" from roof. So the point of attachment for the drop would be at 30".
Old 04-29-2010, 08:50 PM   #7
Les Voltage
I would see if the poco adding a jump pole is an option.
Old 04-30-2010, 12:50 AM   #8
Rewards Points: 2,000
You can buy a guy kit at your supply house. Fairly common item around here.
200 Amp Mast Service Magnettica Services and Service Equipment 50 04-29-2010 11:03 PM
Service drop attachment to a mast service Magnettica Services and Service Equipment 55 04-27-2010 12:48 AM
Service Mast / GFCI John Samuel General Electrical Discussion 26 04-16-2010 11:24 PM
service mast guying electricalperson Services and Service Equipment 10 11-24-2008 11:52 PM
PVC Service Mast? Smileyboy Services and Service Equipment 15 11-12-2008 01:39 AM
