Old 04-14-2011, 07:03 PM   #1
DMILL's Avatar
Default Shed
My girlfriends dad is building a detached 10x10 shed and wants one light, switch, and recept. How would i switch from emt, to pvc, then back to pvc?
Derrick Miller
DMILL is offline   Reply With Quote
Old 04-14-2011, 07:26 PM   #2
Heavily Armed Member
HARRY304E's Avatar
They make threaded PVC Couplings..
Old 04-14-2011, 07:29 PM   #3
DMILL's Avatar
Well what i meant is what would the best way to exit the garage, and enter the shed? As in how would i penetrate the walls since theres concrete floors in both? I want it to look good though
Derrick Miller
Old 04-14-2011, 07:33 PM   #4
3rd Generation
MF Dagger's Avatar
You should wait a year or two to do this task alone. It's okay to tell the old man that you aren't able to do it yet on your own.
Beercan ceiling fan.
MF Dagger is offline   Reply With Quote
Old 04-14-2011, 07:34 PM   #5
HARRY304E's Avatar
Just stub up the outside wall as low as you can and go in with an LB..
oldschoolvdub (04-16-2011)
Old 04-14-2011, 07:36 PM   #6
DMILL's Avatar
Thank you
Derrick Miller
Old 04-14-2011, 07:49 PM   #7
Head Grunt
You can do an LB on the inside too as long as it is accessible, i am sure you are working with 2X4 studs.
No free man shall ever be debarred the use of arms.-Thomas Jefferson
woodchuck2 is offline   Reply With Quote
Old 04-14-2011, 10:16 PM   #8
Tabihu Juhar
76nemo's Avatar
Many of us specialize in one or two things. It's like thee ol' saying, "You're a lineman..........."
He's got a few hours in:
Pipe work
I'm sure he'll last the FULL eight seconds. Hehehe : )
Old 04-14-2011, 10:43 PM   #9
DMILL's Avatar
Pipe work
Please explain haha
Derrick Miller
Old 04-14-2011, 10:44 PM   #10
DMILL's Avatar
Yessir just 2x4 studs with tin siding
Derrick Miller
Old 04-14-2011, 10:53 PM   #11
Tabihu Juhar
76nemo's Avatar
Please explain haha
'Twas you that did that layout, correct? You just stuck on pipe and not inside wiring?????????
Old 04-14-2011, 10:53 PM   #12
Master Plumber
TOOL_5150's Avatar
The other suggestions are ok, But to make it code compliant, instead of using an LB to enter, Use a bell box, and put a single pole 20A switch, or 15 if you wish to be your disconnect, then throw a WP cover on that and you are good to go.
~Matt
Poor planning on your part does not constitute an emergency on my part.
Old 04-15-2011, 06:48 AM   #13
Call an electrician. He'll know what to do.
Old 04-15-2011, 09:19 AM   #14
Use a standard 4" square junction box.
But, all kidding aside, if you have to ask how to do this, this task is over your head.
Old 04-15-2011, 02:55 PM   #15
Coaster Sparky
thegoldenboy's Avatar
Harry, I hope you mean PVC Female Adapters.
Why not do the whole thing in PVC? Switch between Sch. 40 and Sch. 80 as needed or stick with Sch. 80 throughout. Don't forget your expansion couplings.
I saw a girl texting & driving the other day & it really made me mad, so I rolled down my window & threw my beer at her.
thegoldenboy is online now   Reply With Quote
Old 04-15-2011, 09:30 PM   #16
DMILL's Avatar
I can do this, i just wanted to know for sure
Derrick Miller
Old 04-16-2011, 09:50 AM   #17
3rd Generation
MF Dagger's Avatar
Make sure to take pictures
Old 04-16-2011, 10:29 AM   #18
Okie dokie.
I wouldn't bother using any EMT. Keep it all PVC.
Old 04-16-2011, 11:56 AM   #19
DMILL's Avatar
Ok, thanks guys
Derrick Miller
Old 04-16-2011, 01:22 PM   #20
Sideways Sparky
farlsincharge's Avatar
Do you guys have to use pipe for U/G? I have never seen it done here.
farlsincharge is offline   Reply With Quote
Shed Wiring AMPED NEC Code Forum 2 03-28-2011 11:51 AM
Shed power..... Mr. Sparkle Off Topic 30 03-13-2011 04:23 PM
New shed wiring GEORGE D General Electrical Discussion 10 05-16-2010 12:51 PM
shed donny General Electrical Discussion 2 08-12-2009 12:19 PM
wireing shed donny NEC Code Forum 0 08-12-2009 11:47 AM
