Closed Thread
Old 02-16-2009, 03:13 PM   #1
Default solder connections
hello''is solidering of electrical connections a better connection?
as opposed to wire nuts?
is soldering legal? i have seen electricians solder the grounds
and I have solidered copper braded grounds for towers
zapped twice is offline
Old 02-16-2009, 03:27 PM   #2
electricalperson's Avatar
i dont know if its better but all the solder is doing is the same exact job as a wire nut. it just holds the wire together. IMO a connection should not rely on the wirenut or solder alone. your splices are what holds it all together
electricalperson is offline
Old 02-16-2009, 03:49 PM   #3
NO high voltage here
solder and heatshrink will provide a better connection. not sure if thats what is supposed to be done though.
what kind of wire is this too? that will also make a difference
mikeh32 is offline
Old 02-16-2009, 04:18 PM   #4
Speedy Petey's Avatar
(B) Splices.
Conductors shall be spliced or joined with splicing devices identified for the use or by brazing, welding, or soldering with a fusible metal or alloy. Soldered splices shall first be spliced or joined so as to be mechanically and electrically secure without solder and then be soldered. All splices and joints and the free ends of conductors shall be covered with an insulation equivalent to that of the conductors or with an insulating device identified for the purpose.
Speedy Petey is offline
Old 02-16-2009, 04:30 PM   #5
"A" inside wireman
randomkiller's Avatar
It depends on the job specs and type of install, we have had to solder per specs on some telco and poco jobs.
"One Nation Under God"
randomkiller is offline
Old 02-16-2009, 04:57 PM   #6
Default soldiered
the application is the pigtailing of connections in a residental home
it sounds as if its ok to solder..the connections
Old 02-16-2009, 05:01 PM   #7
a better connection probably would be to leave one of the conductors long and strip the middle then splice them all together and solder. this is the way i do it with crimps and the EGC when i cut in boxes
Old 02-16-2009, 05:21 PM   #8
thanks..the last home i had. I had problems with light bulbs blowing all the time i traced it down to loose pigtails thanks guys
Old 02-16-2009, 06:04 PM   #9
I'm not sure how this thread got by me. Oh well.
You can solder them if you want. The solder CANNOT be the sole means of connection and the splice MUST be mechanically sound BEFORE soldering.
As this is obviously a DIY project I must say:
Please take a moment to post your question at www.DIYChatroom.com If your not already a member of DIYChatroom.com you can sign up for a free account by going to http://www.diychatroom.com/register.php/
Closed Thread
Bus Bar VS Cable Connections Cathy Hui General Electrical Discussion 0 01-06-2009 01:53 AM
cleaning buss connections sparky970 General Electrical Discussion 8 09-03-2008 08:21 AM
12V Lighting Connections megavolt Lighting Design 11 04-18-2008 07:42 PM
wet coax & uhf connections?? crazy_campo Structured Wiring 8 12-27-2007 04:38 PM
You Just Gotta Tighten Those Connections! brian john Workplace Safety 8 03-20-2007 06:02 PM
