Old 07-15-2009, 07:42 PM   #1
Seen your member
Default Solve This Service Call : Chapter 2
OK, here's another one for ya. Customer has a circuit breaker in his barn (on a farm) that won't reset. Here's the panel:
Other symptoms: Exterior HID doesn't work, and some inside lights won't work either.
So given the situation and known facts, what would your next step be?
(Let's ignore the shopping list of violations for a moment, and concentrate on getting power back on!)
Please note: I already know what the problem is. It has been located and corrected. The reason all the breakers are closed in the photo is because I HAVE FOUND THE PROBLEM.
I am not 'fishing' for a solution. This is simply an exercise to help those interested in honing their troubleshooting skills.
To anything!
Old 07-15-2009, 07:51 PM   #2
child please.....
NolaTigaBait's Avatar
Start at the panel check obvious stuff first. Then,start breaking some of the taps at the lights apart, try to narrow my search.
Old 07-15-2009, 07:52 PM   #3
drsparky's Avatar
First I would check input on both legs. L1 to N L2 to N, L1 to L2, L1 and L2 to ground. What do I get?
Chuck
Old 07-15-2009, 07:58 PM   #4
Burger Flipper
TOOL_5150's Avatar
Send a message via ICQ to TOOL_5150 Send a message via AIM to TOOL_5150 Send a message via MSN to TOOL_5150 Send a message via Yahoo to TOOL_5150
I would check all the voltages as mentioned above, including N - G, just because. THen id figure out the best place to isolate parts of the ciruit, and break it into parts. I would take a look at the outside HID and see if its in good shape, and probably check that specifically as well.
~Matt
Old 07-15-2009, 08:00 PM   #5
child please.....
Am i missing something?....Why check the voltage?...isn't it a dead short?
Old 07-15-2009, 08:04 PM   #6
I bet the farmer swore as soon as you got there that "the breaker must be bad" .
Old 07-15-2009, 08:07 PM   #7
Seen your member
Not necessarily. I just said it won't reset. But here's another hint: When it's turned on, it buzzes sporadically for 3-4 seconds, then opens.
Actually, he wasn't even home. He always leaves the barn open, so I just went out first thing this morning before it got hot.
To anything!
Old 07-15-2009, 08:07 PM   #8
Could be a faulty breaker. I'd check all the voltages in the panel, and see if the breaker has voltage without the circuit. Then reconnect the circuit split it in the middle somewhere and try to narrow down my search to a smaller area of the circuit.
crazyboy is offline   Reply With Quote
Old 07-15-2009, 08:08 PM   #9
Burger Flipper
TOOL_5150's Avatar
I check everything - no matter what the customer tells me. That is a key part of troubleshooting the correct way.
~Matt
Old 07-15-2009, 08:09 PM   #10
Check load from bad breaker from known good breaker?
Old 07-15-2009, 08:38 PM   #11
steelersman's Avatar
swap out breaker that won't reset with one of the known good ones to see if it resets.
Old 07-15-2009, 08:39 PM   #12
Burger Flipper
TOOL_5150's Avatar
You wouldnt just pull the wire from the breaker and see if holds first?
~matt
Old 07-15-2009, 08:41 PM   #13
Nope. That would make too much sense and be to easy! I like to do more work than necessary!
Old 07-15-2009, 08:46 PM   #14
Burger Flipper
TOOL_5150's Avatar
Ahh, you must get paid hourly as well
~matt
Old 07-15-2009, 08:53 PM   #15
B4T Scotchkote installer
Black4Truck's Avatar
I would seperate the load at first junction box, see if breaker holds, and see if one of the fixtures has a short.
Black4Truck is offline   Reply With Quote
Old 07-15-2009, 08:58 PM   #16
Seen your member
OK, so how do you determine which cable it is?
To anything!
Old 07-15-2009, 09:00 PM   #17
~matt
Yes for my fulltime job, but not for my side jobs. I prefer to charge per the job at hand. I can make much more that way.
Old 07-15-2009, 09:03 PM   #18
First thing I do is stick a meter in there and see what voltages I got, just as a first principle. The next thing I do is pull the wire off the breaker and see if it holds. If it does, I put the wire back on and see if I can get an amp reading.
If it stays on for more than a second or two, it is unlikely to be a dead short. At 3 or 4 seconds, knowing it is a lighting circuit, I'd suspect a bad ballast.
Then, I'd call the plumber and tell him I found out why the drains were clogged.
Old 07-15-2009, 09:04 PM   #19
Disconnect hot, neutral, and ground and push wire up into pipe
Old 07-15-2009, 09:07 PM   #20
Nah, too much work. Take your hot stick and find out which one isn't hot
Solve This Service Call 480sparky Residential Electrical Forum 95 07-09-2009 08:00 PM
Leg loss service call wirenut1110 General Electrical Discussion 13 06-07-2009 07:43 PM
Service call in my pajamas MDShunk General Electrical Discussion 35 06-06-2009 03:39 PM
GM considering Chapter 11 filing, new company: Minuteman Off Topic 7 02-15-2009 01:28 PM
