Old 07-31-2009, 07:33 PM   #21
Senor Frijolero
fraydo's Avatar
If the meter is blinking on and off maybe a lug on the line side of the meter is broken off or hanging by a thread. When our local POCO switched to digital meters they broke lots of old cans and had us replace them.
fraydo is offline   Reply With Quote
Old 07-31-2009, 07:34 PM   #22
Arcing. The meter is a new digital job, and the display would go on and off.
So, it's on the line side of the meter.
Old 07-31-2009, 07:43 PM   #23
Seen your member
A-yep!
Old 07-31-2009, 08:09 PM   #24
Senor Frijolero
fraydo's Avatar
So you change out the meter can and ask for a cold glass of lemonade for your troubles?
Old 07-31-2009, 08:18 PM   #25
Seen your member
Naaa. I just placed some cardboard against the front cover and crimped the jaws with an arc-joint pliers.
Old 07-31-2009, 08:31 PM   #26
So how does the lady kicking the ground box factor into it? Coincidence?
Old 07-31-2009, 08:32 PM   #27
"Euro" electrician
Not very often I did see main cartage fuse holder is inverted from factory however I did get few service call with half power on Mobile homes which it one of few most common depending on the set up.
Half of my time I get POCO conductor actally pull out of lugs when the meter pedestal do " rise " from frost / thaw cycle.
This year I allready done 15 of them.
But really compound it is the bad meter spring to hold the meter lugs that is the other common item I get from time to time.
Yeah I got few with the fused service latheral not buryed deep at all I have one just last week it was only bury 6 inches Deep
Merci,Marc
Old 07-31-2009, 08:55 PM   #28
Seen your member
That's my guess.
Old 07-31-2009, 09:05 PM   #29
Senor Frijolero
fraydo's Avatar
so did you get the lemonade?
Old 07-31-2009, 09:09 PM   #30
Even better:He got a check!
Old 07-31-2009, 09:44 PM   #31
Seen your member
Not really. I'm on a barter system with this guy. We settle up at the end of the year.
Old 07-31-2009, 10:00 PM   #32
Even worse: He got screwed!
Old 07-31-2009, 10:14 PM   #33
Seen your member
No. I just keep a running tally, then at the end of the year, we settle up. It works out well for both of us.
Old 07-31-2009, 10:34 PM   #34
oldschool's Avatar
I do that with my mechanic...
I think it works out better for him
oldschool is offline   Reply With Quote
Old 08-21-2009, 04:51 PM   #35
check the lugs and jaws in the meter can
froggie9189 is offline   Reply With Quote
Old 08-21-2009, 05:20 PM   #36
Yep, these things are exceptionally easy to solve once the OP gives the answer a few posts above. Good job
Old 08-21-2009, 06:01 PM   #37
steelersman's Avatar
What a GD turd you are. Don't you bother reading the entire thread? You DA.
Old 08-23-2009, 12:50 AM   #38
pudge565's Avatar
Had a guy in my technical shool the other year like that. Thought he knew everything but never knew the answer until someone else said it.
Old 08-23-2009, 11:55 AM   #39
BDB
Ummm get paid in cash and does not show up on the books? That would work out well.
Proud Father of a US Army Solider
BDB is offline   Reply With Quote
Old 08-23-2009, 01:08 PM   #40
Seen your member
Uh, no. That would be illegal. I do work for him, and he does some work for me. Instead of writing checks out back & forth all year, we just keep track of both and one of us pays the other at the end of the year.
Far less paperwork, bookkeeping, etc. And taxes still get paid on the full amounts owed as we give each other 1099Miscs every year.
Solve This Service Call : Chapter 2 480sparky Residential Electrical Forum 53 07-30-2009 11:12 PM
Solve This Service Call 480sparky Residential Electrical Forum 95 07-09-2009 08:00 PM
Leg loss service call wirenut1110 General Electrical Discussion 13 06-07-2009 07:43 PM
Service call in my pajamas MDShunk General Electrical Discussion 35 06-06-2009 03:39 PM
