Old 04-15-2012, 06:27 AM   #1
Default somebody real smart did this
Went on a service call yesterday, Carpenter friend of mine called said he was on a job doing some remodel work. Home owner had an old outbuilding that he needed the Electric cut loose from.So i go to jobsite.I pull the cover on the200 amp disconnect box.there is a 10-2 wire double lugged to the main lugs of the disconnect. on the other end the#10 wire was wired into a100amp main breaker of the sub panel. Some people have no clue.
Teaspoon is offline   Reply With Quote
Old 04-15-2012, 07:13 AM   #2
Heavily Armed Member
HARRY304E's Avatar
I wonder what the connected load in the sub panel is?
Old 04-15-2012, 07:31 AM   #3
The connected load does not matter, the wire is protected by a 100 amp breaker. The wire would melt before it ever hit the trip.
Dammonn is offline   Reply With Quote
Old 04-15-2012, 08:00 AM   #4
Lite em up !
mrmike's Avatar
In Respect, the connected load does matter, as the wire never melted, so we know that it was at or below the wire's capacity...................
mrmike is offline   Reply With Quote
The Following User Says Thank You to mrmike For This Useful Post:
BBQ (04-15-2012)
Old 04-15-2012, 08:01 AM   #5
jrannis's Avatar
1- 60 watt lamp, 1-Bug Zapper, 1- beer fridge.
"When a your only tool is a hammer, every problem looks like a nail"
jrannis is offline   Reply With Quote
The Following 2 Users Say Thank You to jrannis For This Useful Post:
BBQ (04-15-2012), dronai (04-23-2012)
Old 04-16-2012, 06:57 AM   #6
Looked like there had been a few lights & Receptacles. The building was empty when I got there. It is to be torn down.
Old 04-16-2012, 07:10 AM   #7
976-EVIL
mcclary's electrical's Avatar
Outside tap rule...
Old 04-23-2012, 03:04 PM   #8
JDJ
Friend is moving shop asked me to help clean up new locations electrical. FP panel which I love. I'll have to take a pic of the #12 bugged behind "B" phase on the line side of the main that feeds to a single breaker enclosure for the exit lights. Good times.
JDJ is offline   Reply With Quote
Old 04-23-2012, 04:50 PM   #9
Awg-Dawg's Avatar
I still see that from time to time.
Usually, 2pole fusible discos tho.
I'm just hoping to not end up on Electricmanscotts signature line.
Awg-Dawg is online now   Reply With Quote
Old 04-25-2012, 04:31 AM   #10
Tap rule, perfectly legal if under 25', and done correctly.
I've seen hot taps into main buss bars.
noarcflash is offline   Reply With Quote
The Following User Says Thank You to noarcflash For This Useful Post:
JDJ (04-25-2012)
Old 04-25-2012, 09:19 AM   #11
JDJ
Thanks . Had forgotten about this.
Old 04-26-2012, 06:17 PM   #12
Not here at the moment
Dnkldorf's Avatar
How would this be a sub-panel?
If fed from the line side of the service disconnect, that would make that a main panel, no?
Dnkldorf is offline   Reply With Quote
Old 04-28-2012, 02:16 AM   #13
I never grasped the tap rules. Can someone expound on them snd learn me sometin!
God man is offline   Reply With Quote
Old 04-28-2012, 06:00 AM   #14
Those are the rules that allow you to tap and drop the wire size to below what the breaker will open at, but if you try using a smaller wire than a generator overcurrent protective device, you will go to hell for it........
Proof and exoneration http://www.latimes.com/news/politics...,7305052.story
Old 04-28-2012, 06:27 AM   #15
BBQ
BBQ's Avatar
Consider an outdoor genset with a 100 amp breaker, but you only need 60 amps.
You could run 6 AWG from that 100 amp breaker to a 60 amp breaker or fuse at the house using the outside tap rules.
BBQ is online now   Reply With Quote
Old 04-29-2012, 08:01 AM   #16
Gold Member
#10 melt at 100amps? I HIGHLY doubt that. I have seen 14 running 60amps. It was warm to the touch(that's how i accidentally discovered it!), but nowhere near melting.
Ontariojer is offline   Reply With Quote
Old 04-30-2012, 02:06 AM   #17
Check this youtube link and this may will change your mind on this one the youtube the person say it was on 20 amp circuit so it will be 4.0mm2 ( #12 awg ) and it ran 60 amp on that conductor so see it yourself.
YouTube Video
ERROR: If you can see this, then YouTube is down or you don't have Flash installed.
Merci,
Marc
Old 04-30-2012, 06:51 AM   #18
Gold Member
YouTube Video
Merci,
Marc
Really? That video seemed a little suspect to me. If 60A did that to #12 there would be A LOT more house fires.
Is just under 1watt per inch enough to smoke that wire? Because thats the heating of #12 wire, two conductors, at 60 amps. I doubt it. Similarly, #10 2 conductor would be 1.6watts/inch at 100amps.
Someone please check my math
Old 04-30-2012, 06:55 AM   #19
BBQ
BBQ's Avatar
Lets qualify things a bit.
12 Copper will not melt with 60 amps of current.
The insulation may smoke, but the copper will be fine.
I think 14 AWG copper becomes a fuse somewhere around 200 amps in free air.
So exactly what are we saying will happen?
Old 04-30-2012, 08:23 AM   #20
Gold Member
I am saying the following.
I have personally seen a 14/2 with the following loads. 6x500w halogen worklight heads, a 12" chop saw, A wet tile saw, a skilsaw and a fridge. All going at once.(obviously the saws and fridge were intermittant, but going pretty frequently, all day). The wire was tight against(but not surrounded by) fiberglass insulation. It was summer, and it was hot.
The wire was definitely warm to the touch, but not hot.
FPE 15a brkr, in case you were wondering.
Just sayin.
One smart dog.. B4T Off Topic 10 12-28-2011 08:33 PM
More on Smart Meters wildleg General Electrical Discussion 2 10-22-2011 12:35 PM
Try this smart guy Shawn23 NEC Code Forum 13 05-07-2011 10:36 AM
Smart Phones manchestersparky Off Topic 5 11-18-2010 08:19 PM
How Smart are Smart Meters Serge General Electrical Discussion 1 04-09-2010 12:10 PM
