Spray foam in outlet boxes - Electrician Talk - Professional Electrical Contractors Forum
Old 03-21-2012, 08:46 PM   #1
Default Spray foam in outlet boxes
I'm working on a remodel house and the owner has hired an energy super saver company. Before I get there to replace receps and switches they have spray foamed all the outlet boxes full. Would that be in the n.e.c? Box fill? Is it dangerous? Something about it has me spooked.
daylen22 is offline   Reply With Quote
Old 03-21-2012, 09:22 PM   #2
Rewards Points: 278
I would make them come back and clean it out
The Following 6 Users Say Thank You to Dennis Alwon For This Useful Post:
3xdad (03-23-2012), CDN EC (03-22-2012), frenchelectrican (03-23-2012), JohnR (03-22-2012), OKelectric (03-25-2012), wildleg (03-21-2012)
Old 03-21-2012, 09:26 PM   #3
animal lover /rat bastard
wildleg's Avatar
Rewards Points: 368
something about it ?
how about - everything about it !
violation !
Old 03-21-2012, 09:35 PM   #4
Theriot's Avatar
Rewards Points: 1,000
I was told that we should down rate our romex because the heat can't escape. So 12 is really a 14. Has anyone else heard this?
Theriot is offline   Reply With Quote
Old 03-21-2012, 10:00 PM   #5
Rewards Points: 150
+1
Mark
wesleydnunder is offline   Reply With Quote
Old 03-22-2012, 05:18 AM   #6
Rewards Points: 1,464
No.Not I.
Old 03-22-2012, 05:31 AM   #7
kbsparky's Avatar
"Romex®" is already downrated (90º wire required to be installed at no more than 60º) , so further derating is not necessary.
-KB
Old 03-22-2012, 09:45 AM   #8
RIP 1959-2015
HARRY304E's Avatar
Rewards Points: 1,344
The boxes should not be filled with foam and they should have to pay to clean them out.
Welcome to the forum....
Old 03-22-2012, 10:40 AM   #9
110.12B prohibits foreign objects from inside a j-b
Old 03-22-2012, 03:38 PM   #10
And that spray foam is probably flammable too...
I also say make that energy company come clean it out..and report them to whatever agencies will get them shut down for creating a major hazard.
The proper thing to use is the foam gaskets that fit between the device and the cover plate.
Old 03-22-2012, 07:51 PM   #11
In Canada, it says:
Section 2 (general rules)
2-122, 2
Thermal insulation material shall not be sprayed or otherwise introduced into the interior of outlet boxes, junction boxes, or enclosures for other electrical equipment.
kaboler is offline   Reply With Quote
The Following User Says Thank You to kaboler For This Useful Post:
kawimudslinger (03-23-2012)
Old 03-23-2012, 04:58 AM   #12
Rewards Points: 534
I have ran into couple of them do that even some homeowner done the same thing as well they will spray the foam inside the box by time something don't work they have to call me in and find the junction box is really stuffed with expaning foam that can be pain in arse to get it out.
With the junction box filled with expanding foam or other type of foam it will make it very differcult to do the troubleshooting.
As soon I did see couple of them stuffed and told the owner of that place whomever did spray it will cost the time and money ( the owner told me that was one company did that ) so told that company they have two choice either they come back and remove all the foam from all the junction boxes they spray in or I will backcharge them so they choose the latter so end up send them pretty good size bill to them.
Merci,
Marc
3xdad (03-23-2012)
Old 03-23-2012, 01:52 PM   #13
Rewards Points: 2,746
If the $5 an hour felon work force hired to apply the sprayfoam comes out to remove the foam from the boxes, most likely the wire in the boxes will be removed as well during the process.
I often wonder where the other trades get the people they hire and send to jobs. Somehow the zoo figures into this.
Spray foam? Elephante General Electrical Discussion 27 01-16-2012 05:33 PM
Foam sprayed attics Shawn23 Other Codes and Standards 11 02-25-2011 08:08 PM
spray foam s.kelly General Electrical Discussion 28 06-05-2010 10:01 AM
Spray can pvc cement macmikeman Tools, Equipment and New Products 5 04-07-2009 12:44 PM
installing outlet boxes heyhi NEC Code Forum 13 09-07-2008 05:25 PM
