Closed Thread
Old 07-18-2009, 04:37 PM   #1
Default thermostat wiring
I just bought a honeywell 7500 , 7 day programable thermostat for my heating & central air .The thermostat has a full auto mode that lets you keep the house at a steady temperature all the time.It will turn the heat on when needed or the ac when needed to keep the room at the set temperature.I have two seperate units for heat and air and I cannot find a diagram or any information on how to wire this to make that function work.The way I have it wired now i have to manuelly change from heat to ac.I was also wondering if there is a way to keep the backlight lit on the thermostat so I can see it at night without turning the light on.i was going to put a jumper from the R to the L connectors but I wasnt sure if that would work
sourmash is offline
Old 07-18-2009, 04:44 PM   #2
Please post this to www.diychatroom.com
Speedy Petey is online now
Closed Thread
Line Voltage Thermostat How many baseboards can I connect? coswald General Electrical Discussion 11 11-24-2008 01:15 PM
3 phase thermostat jjdrees General Electrical Discussion 3 11-18-2008 06:20 PM
Advice please: Programmable Room Thermostat dipsb_13 UK Electrical Forum 5 02-24-2008 05:10 PM
Connect Honeywell RTH230B thermostat one pole 240 gilamor General Electrical Discussion 3 07-05-2007 01:11 PM
Help to set up thermostat on gas heater jayendra General Electrical Discussion 5 06-22-2007 08:39 AM
