04-12-2012, 04:06 PM
#21
Originally Posted by Chris1971
210.12B of the 2011 NEC.
"where branch circuit WIRING is modified...." how is replacing a receptacle modifying wiring? Let's say it's a dead end box with a hot and a neutral. You take off the old receptacle, put on a three prong. How has the WIRING been modified? A device is not "wiring".
04-12-2012, 04:13 PM
#22
So, we can install a GFCI receptacle to replace the existing two prong receptacles
Receptacles do not have prongs, next week we will go over the differences between girls and boys.
You are not really and electrician are you?
04-12-2012, 04:15 PM
#23
The Following User Says Thank You to Chris1971 For This Useful Post:
04-12-2012, 04:17 PM
#24
Still a modification, IMO.
04-12-2012, 04:24 PM
#25
You're wrong, IMO.
04-12-2012, 04:25 PM
#26
PES
Hey if you wanna change it, so be it
Sal
P.E.S
04-12-2012, 04:33 PM
#27
Oh crap!!! I thought I was logged into plumbertalk.com
04-12-2012, 04:34 PM
#28
You're wrong, IMO.
Maybe, maybe not.
04-12-2012, 04:38 PM
#29
Maybe, maybe not.
Maybe  ...... Here's what Minnesota has to say about it.... I'm sure many other states have the same mindset. Will find more later....
443 Lafayette Road North St. Paul, Minnesota 55155 www.dli.mn.govw www.electricity.state.mn.us
(651) 284-5064 1-800-DIAL-DLI Fax: (651) 284-5743 TTY: (651) 297-4198
2011 National Electrical Code® Questions & Answers
1. Will the replacement of a residential panelboard be considered a “circuit modification” and
prompt the new requirement in 210.12 for AFCI protection of existing branch circuits?
201.12(B) Branch Circuit Extensions or Modifications — Dwelling Units. In any of the areas specified in 210.12(A), where branch-circuit wiring is modified, replaced, or extended, the branch circuit shall be protected by one of the following:
(1) A listed combination-type AFCI located at the origin of the branch circuit
(2) A listed outlet branch-circuit type AFCI located at the first receptacle outlet of the
This change requires a branch circuit to have combination‐type AFCI protection when there is an extension or modification. “Branch circuit” is defined in Article 100 as “The circuit conductors between the final overcurrent device protecting the circuit and the outlet(s).” The overcurrent device is not part of the branch circuit and replacing the circuit breaker is not a modification of the branch circuit.
Answer: When the conductors of an existing branch circuit are disconnected from an overcurrent device in an existing panelboard and simply re‐terminated on a new overcurrent device in a new panelboard, the branch circuit wiring has not been modified or extended, therefore AFCI protection would not be required.
The US Consumer Product Safety Commission, CCPC, states “Although the requirement is limited to certain circuits in new residential construction, AFCIs should be considered for added protection in other circuits and for existing homes, as well. Older homes with aging and deteriorating wiring systems can especially benefit from the added protection of AFCIs. AFCIs should also be considered whenever adding or upgrading a panel box while using existing branch circuit conductors.”
04-12-2012, 04:46 PM
#30
There is no one answer for this, it is entirely a local call and real waste of time to argue about on a national level.
04-12-2012, 04:47 PM
#31
Just called my local building and safety and spoke to inspector. Replacing a device is considered "maintenance" and does not constitute a "modification" that would require the installation of an arc fault device. I also asked about this issue, replacing ungrounded receptacles with grounded receptacles, and installing a GFI at the beginning of the circuit and he said "nope, that's maintenance. No arc fault required.". However, I suppose that could differ with every AHJ.
04-12-2012, 10:23 PM
#32
Can we still argue this point?
04-12-2012, 10:26 PM
#33
Words
I like Maintainance and Existing. Those are two great words
The Following User Says Thank You to Cletis For This Useful Post:
04-12-2012, 10:27 PM
#34
There's no argument as far as I'm concerned. I won't be putting in Arc Faults when I replace receptacles. You can.
The Following User Says Thank You to B W E For This Useful Post:
04-12-2012, 10:30 PM
#35
Yeah, not by choice on my end.
04-12-2012, 10:32 PM
#36
It is your choice. You choose to interpret the code incorrectly and mistakenly assign definitions to things contrary to the NEC. Call your ahj and ask them. If I'm wrong, I'll send you a gift certificate for see's candy
04-12-2012, 11:43 PM
#37
Resi Service Electrician
For arguments sake; what if you pigtail the connections when you replace the receptacle? I do this anytime I touch a plug...
"Understand one thing every one has a place in this trade, and no matter what your skill set I doubt you know it all." brian john
04-12-2012, 11:49 PM
#38
Sounds like you modified the wiring of the branch circuit. Good point.
04-12-2012, 11:57 PM
#39
The branch circuit conductors were not extended to another location to perform another function. I'm beginning to think you're not serious, and are just curious to see what kind of arguing endurance I have....
04-17-2012, 08:38 PM
#40
AHJ requires it in one municipality.
