sounds like to me it could be a bad upstream receptacle where something is plugged into it and causeing a voltage drop downline to your receptacle. Most receptacles are stabbed in the back if it has been there for a few years. Sometimes romex jockeys still stab them in the back.
Ill be glad when the receptacles only have 1 hot,1 neutral, 1 ground terminal and no place to stab wires to avoid this from happening!
If this is dedicated, check the breaker and I would also make sure what is all on the circuit, it could be shared with another hot or accidently with another neutral. Ive seen 2 hots and neutrals in a box and the neutrals get crossed up.
You have the ring, and I see that your schwarz is as big as mine.  May the schwartz be with you!
