Closed Thread
Old 11-17-2009, 10:52 AM   #1
Default Wall Oven amp load question
I need to replace my wall oven. It is running on a 4 wire 220V with a 40 amp breaker (2 20amps - double pole). THe new wall oven I am looking at is a 220v but has a max amp load of 20 amps. Am i going to need to have the 40 amp breaker replaced with a 20 amp breaker(2 10 amps - double pole) ? I'm a home improvement guy and handle basic electrical and will get an electrician to do this but just wanted some background info - Thansk. Jim
205bhamjim is offline
Old 11-17-2009, 10:59 AM   #2
sparks134's Avatar
they are both the same breaker!!!
sparks134 is offline
Old 11-17-2009, 11:12 AM   #3
chenley's Avatar
You need a 20A double-pole. As you described above you don't add up the amperage for each pole on the breaker. So you're "2x20A" breaker is a 20A double-pole, which is what you need.
chenley is offline
Old 11-17-2009, 11:21 AM   #4
sparks134's Avatar
this guy is a Do-it yourselfer!!! hes describing the same exact breaker!!! he has no clue!
Old 11-17-2009, 11:30 AM   #5
Default thanks chenly
I appreciate you explaining and answering the question instead of just giving a "smart" comment.
Take care.
Old 11-17-2009, 12:45 PM   #6
chenley's Avatar
Yeah, should've let him install a 10A DP, then wonder why it's tripping everytime he uses it. Well, if there was such a thing.
chenley is offline
Old 11-17-2009, 01:12 PM   #7
Seen your member
Step 1: Get your electrician.
Step 2: Let your electrician worry about it. That's what we get paid for.
480sparky is offline
Old 11-17-2009, 01:46 PM   #8
Please take a moment to post your question at www.DIYChatroom.com If you're not already a member of DIYChatroom.com you can sign up for a free account by going to http://www.diychatroom.com/register.php/
Speedy Petey is offline
Closed Thread
Load Bank Generator Testing vs. Using Building Load to test generators. MR MAB Other Codes and Standards 15 03-16-2009 06:37 PM
minimum ampacity load question heyhi NEC Code Forum 27 10-19-2008 01:35 PM
septic tank pumps + oven philip657 UK Electrical Forum 23 02-13-2008 04:51 AM
Do we need neutral for 240 volts oven or air-condition system gilamor General Electrical Discussion 23 01-08-2008 11:02 AM
220 Volt Oven Circiut mhastings General Electrical Discussion 1 07-03-2007 04:49 PM
