Warm Circuit Breaker - Electrician Talk - Professional Electrical Contractors Forum
Closed Thread
Old 12-13-2010, 08:57 AM   #1
Default Warm Circuit Breaker
I have a space heater that runs of 1,500 watts, 120 volts, 12.5 amps.
I have had it running for approximately 30 hours straight. The circuit configuration for this heater is Leviton 20 amp outlet, 12/2 Romex and a 20 amp C-H Circuit Breaker all recently installed (new).
I just checked the circuit breaker on which the space heater is running and the circuit breaker feels warm to the touch, not hot, not cold, but warm. There is nothing else is running on this circuit. The other circuit breakers feels cold. Additionally, the 12/2 romex wires also feel warm and the wires not under heavy load use feel cold.
The thing is I noticed is the 12/2 wires to be warm about 20 minutes after running the space heater and after checking the wires after the space heater has been on for 30 hours straight they are still warm.
I have read that this is normal and nothing to be worried about, due to the high current flow the space heater is drawing. Is this correct?
Thank you for your help.
ElectricMan2 is offline
Old 12-13-2010, 09:42 AM   #2
Fried Bologna um um good!
jwjrw's Avatar
Yes. When a conductor or circuit has a load on it heat is produced. Some wires can get too hot to touch and be functioning properly.
jwjrw is offline
The Following User Says Thank You to jwjrw For This Useful Post:
ElectricMan2 (12-13-2010)
Old 12-13-2010, 09:58 AM   #3
Rewards Points: 250
You might check the temperature of the conductors at your terminations. If the temperature is constant from one end of the run to the other then I would say is pretty normal. If it heats up at the terminations you might want to check them.
Jbird66 is offline
Old 12-13-2010, 10:30 AM   #4
evil bastard
mcclary's electrical's Avatar
Rewards Points: 746
To cheeck the temperature of the terminations, use the same method as above. Check under load while energized. USe bare feet to you don't get shocked.
mcclary's electrical is offline
randas (12-13-2010)
Old 12-13-2010, 10:41 AM   #5
Speedy Petey's Avatar
Rewards Points: 1,622
Thanks for posting on ElectricianTalk.com. The Admin & Moderators of this forum would prefer if you post Do It Yourself related topics on our sister site www.DIYChatroom.com
Please take a moment to post your question at www.DIYChatroom.com If you're not already a member of DIYChatroom.com you can sign up for a free account by going to http://www.diychatroom.com/register.php/
Speedy Petey is offline
The Following User Says Thank You to Speedy Petey For This Useful Post:
The_Modifier (12-14-2010)
Closed Thread
i need help in circuit breaker!! bird10 General Electrical Discussion 1 08-17-2009 09:48 PM
Circuit Breaker Tester Absolutetruthz General Electrical Discussion 14 05-16-2008 02:39 PM
gfci breaker circuit ? french connection!! NEC Code Forum 15 12-29-2007 02:03 PM
Circuit Breaker Tester brian john General Electrical Discussion 7 10-23-2007 07:39 PM
Are Circuit Breaker Reusable OCP brian john Workplace Safety 2 03-21-2007 08:15 PM
