Old 01-30-2009, 05:24 AM   #1
Default water pump
Just tested a rain water pump. The portable appliance tester came up ok (earth & insulation resistance). Plugged into power point & it tripped the rcd as the pump started up. The power point tested ok when I meggered it. Any ideas?
Lukes is offline   Reply With Quote
Old 01-30-2009, 06:45 AM   #2
Luke this is the second thread with a bad RCD. Is it possible you have a bad batch of RCD's. I am assuming you changed the RCD's out with new ones.
If the circuit megged out as Okay then there is something in the pump that is causing the issue. We have had problems here in the US with garden water feature pumps and GFCI problems. Everytime it was the pump.
Old 01-30-2009, 06:53 AM   #3
I replaced the rcd. I think there may be an internal fault with the pump but wasn't 100% sure.
Old 01-30-2009, 08:32 AM   #4
Did you test the pump itself or only the pressure switch in the off position? Some pressure switches can be manually operated.
AussieApprentice is offline   Reply With Quote
Old 01-30-2009, 11:15 AM   #5
Chalk up another one for nusience tripping.
Pump Pliers? Gents Tools, Equipment and New Products 10 11-10-2008 09:32 PM
120 vs. 240 pool pump wirenut1110 General Electrical Discussion 15 06-21-2008 09:56 AM
polaris pump problem rebel34 General Electrical Discussion 16 06-09-2008 11:19 AM
I Need HELP finding a well pump???? please mikewardjr General Electrical Discussion 10 10-05-2007 07:39 PM
need help with pump wiring. jhall General Electrical Discussion 11 05-01-2007 04:57 AM
