Old 11-11-2009, 08:16 PM   #21
Licensed Journeyman
nolabama's Avatar
Originally Posted by kbsparky View Post
Does this mean you are not an electrician?
This forum is not for DIY issues ...
Its worse than a DIY 480 says OP is an engineer.
Old 11-11-2009, 08:39 PM   #22
Ha,Ha,Ha...
Too many times I have walked into troubleshoot a problem and the first words I hear "well my neighbor who's an electrical engineer"...LOL
RMatthis is offline   Reply With Quote
Old 11-11-2009, 09:04 PM   #23
Stiff Member
idontknow's Avatar
Wagos!
Seriously though they work great. No twist, no tape, and visual confirmation of connection.
idontknow is online now   Reply With Quote
Old 11-11-2009, 09:29 PM   #24
Originally Posted by idontknow View Post
Wagos!
They make life easier for sure...but I still like to twist all my wires. Call me old school. I have a feeling that in 20 years we'll all be saying, "well those were good in their day but..."
Old 11-12-2009, 03:15 PM   #25
Jobless Extraordinaire
Grimlock's Avatar
Just CAD weld the wires together and be done with it already. (Then tape it)
Grimlock is offline   Reply With Quote
Old 11-12-2009, 03:29 PM   #26
Local 150 Lake County,IL
you need some HV rubber tape, then go 4 times around with Super 33, and then use some shrink tape on it. that should do the trick
running dummy is offline   Reply With Quote
Old 11-12-2009, 04:22 PM   #27
Licensed Journeyman
nolabama's Avatar
you forgot the cambric - I would highly recommend this particular individual application have cambric tape.
HV rubber tape, then cambric then super 33 then the shrink tape that should hold up.
that or a polaris tap
Old 11-12-2009, 05:19 PM   #28
How could I forget!!!
Old 11-12-2009, 10:11 PM   #29
Only a hack would omit the potting compound
heel600 is offline   Reply With Quote
Old 11-12-2009, 11:24 PM   #30
cdnelectrician's Avatar
Better wire em up with teck cable, romex wont hold up!
cdnelectrician is online now   Reply With Quote
Old 11-13-2009, 02:11 PM   #31
Grimlock's Avatar
No, we better go with copper bus just to be on the safe side.
Old 11-13-2009, 03:08 PM   #32
I would use Polaris connectors and then wrap them with an 1/8" minimum of Super 88.
Old 11-13-2009, 05:33 PM   #33
Licensed Journeyman
nolabama's Avatar
So I am a hack-whats potting compound.
dont google it i am gonna do that
Old 11-14-2009, 03:21 PM   #34
Wow, I like the potting compound idea. Actually could could seal the whole light in potting compound, but changing the light bulb would be a B*tch. Enough engineer bashing.
I have decided not to tape the wire nuts. The connectors are sufficient to hold since I tighten them until they scream.
Lets end this thread!
rmsowell is offline   Reply With Quote
Old 11-15-2009, 03:40 PM   #35
Space Rat
Power Tech's Avatar
Aren't the black wire nuts high temp?
I was taught to use those in HID and incandescent ceiling fixtures.
Power Tech is offline   Reply With Quote
Old 11-21-2009, 03:50 AM   #36
zen
electrican
zen's Avatar
Default door jam switch
whats with door jam switches,,,every thing about them gets on my nerves,,first they will be covered up then they are metel ,,have no room in them , an acceptable connector gets in the way or its costly,,you need to tape the terminals its probably gonna short out and the ground screw that comes with it never goes in its place without hassle....is there a good reason no one makes a better one thats plastic..
I can break an unbreakable plate,,,yes i can,,,
zen is online now   Reply With Quote
Old 11-21-2009, 03:10 PM   #37
Holy thread hijack batman!
Here's my suggestion, stop using them, use this instead:
http://www.hankselectric.net/detail.aspx?ID=1087
TimeSaver Model CR-120V (there is also a 20 amp version)
It's a relay, mounted at the fixture. small low voltage wires are run to an alarm contact.
Just don't use the other one, called a Betterswitch. They are unreliable and not UL tested.
egads is offline   Reply With Quote
Old 11-21-2009, 06:17 PM   #38
Send a message via AIM to thekoolcody
You only tape your wire nuts, if you dont know how to splice. If you make a good splice, the nut should fit fine.
thekoolcody is offline   Reply With Quote
Tags
heat, lighting, nuts, tape, wiring
Hot Tub issue jjdrees Residential Electrical Forum 19 07-23-2009 01:34 PM
Stage lighting issue - 1000W BTR lamps, Selecon Rama Fixtures zmhill General Electrical Discussion 0 02-23-2009 12:35 PM
Black Tape? puma1277 General Electrical Discussion 40 01-06-2009 02:25 PM
5" Recess hole saw JohnJ0906 Tools, Equipment and New Products 12 11-17-2008 09:34 PM
No earth wire in lighting circuit????? wattsyboy Other Codes and Standards 1 06-18-2007 10:52 PM
