Go Back   Electrician Talk - Professional Electrical Contractors Forum > Electrical Forum > Introductions
Old 04-10-2012, 10:57 AM   #1
Default per opening
if you guys are charging per opening for a residential project then how do the openings break down. for example is a 4 way switch worth x amount of openings and a fan rated box worth y
will@heartland is offline   Reply With Quote
Old 04-10-2012, 02:07 PM   #2
B W E's Avatar
I would price the 4-way higher due to the different wiring requirements. So, say you're at $50 per single pole switch, I'd do $60 for the 4 way. If your per opening is including the device upon finish, then higher still.
For the fan rated box, I'd use a higher per opening price to account for the higher cost of the box (if there is a higher cost) and the labor to install and hang the fan, if you're doing that. So, for a standard flush mount ceiling fixture, say $50, for a fan rated box and hanging the fan, $150 per opening.
Old 04-10-2012, 11:05 PM   #3
Heavily Armed Member
HARRY304E's Avatar
I'm sure a 4way switch is $5-10 by it's self also the cost of the 3wire as well.
Welcome to the forum OP......
New job opening jwjrw General Electrical Discussion 47 05-11-2011 09:22 PM
Cost per opening Chris1971 General Electrical Discussion 21 04-06-2011 06:12 PM
Inspector Job Opening electricmanscott General Electrical Discussion 2 04-05-2011 08:12 AM
Baseball - Opening Day BIGRED Off Topic 18 04-02-2011 11:55 AM
PRICING sq. ft. vs. per opening trickyricky General Electrical Discussion 47 01-26-2009 01:33 PM
