3 phase calculations. - Electrician Talk - Professional Electrical Contractors Forum
Old 05-01-2011, 01:05 PM   #1
Rewards Points: 288
Default 3 phase calculations.
Hi guys, I have a 3phase sub panel and I need help figuring out the most efficient way to find out how much power is being consumed.Thanks for the help...Its a 3phase 120/208 being fed from a 480/3phase 100amp panel...
knowledge29 is offline   Reply With Quote
The Following User Says Thank You to knowledge29 For This Useful Post:
johnsmithabe (05-19-2011)
Old 05-01-2011, 01:57 PM   #2
Originally Posted by knowledge29
Hi guys, I have a 3phase sub panel and I need help figuring out the most efficient way to find out how much current is being consumed.Thanks for the help...Its a 3phase 120/208 being fed from a 480/3phase 100amp panel...
Power is consumed, current is not.
Either;
turn every thing on and do a current measurement,
find each individual load and do a load calculation,
use a recording power meter for a number of days.
Why do you need this information? Are you planning on adding an additional load to this panel?
K2500 is offline   Reply With Quote
The Following User Says Thank You to K2500 For This Useful Post:
Old 05-01-2011, 03:54 PM   #3
Rewards Points: 2,050
Default Product
Try these. They are great
http://www.emon.com/products.html
Old 05-01-2011, 04:52 PM   #4
Rewards Points: 288
yes,I am planning on installing a 17hp vac systems for a cnc router.
Old 05-01-2011, 11:02 PM   #5
Inspector
electures's Avatar
Rewards Points: 306
Amprobe it or calculate the load.
electures is offline   Reply With Quote
Old 05-02-2011, 07:34 PM   #6
Rewards Points: 25
if you dont know the calculated load of the panel based upon all the connected load, then you should get a recording meter and test it for 30 days to find max and average load.
tgreen is offline   Reply With Quote
Old 05-08-2011, 11:46 PM   #7
Rewards Points: 252
A power quality meter would be best yes, however, if this is your only panel in the plant or site, you could call the power company and they can give you a 12 month readout of consumption, PF, and any 3rd harmonics you might be dealing with. Depending on the PF of the Vac, you might want to consider some PFC to reduce your inductive load a little, and reduce long term power costs.
just my 2c
l0sts0ul is offline   Reply With Quote
Old 05-11-2011, 06:14 PM   #8
remember to carry the 1
alfie1984 is offline   Reply With Quote
Old 05-12-2011, 04:11 AM   #9
Rewards Points: 1,464
It will go "Blooowey"
Old 05-19-2011, 07:01 AM   #10
Why u r installing? Wats ur purpose?
johnsmithabe is offline   Reply With Quote
Old 05-19-2011, 12:08 PM   #11
Rewards Points: 25
Bob had a good catch on this, i didnt even see that they were feeding a 208 panel from a 480 panel.
I guess im just used to speaking with professionals all day,
The Following User Says Thank You to tgreen For This Useful Post:
johnsmithabe (05-20-2011)
Load Calculations 6506gary General Electrical Discussion 18 04-11-2011 08:42 AM
Spa calculations Tapeman General Electrical Discussion 3 09-13-2009 11:14 PM
Math Calculations Hogger NEC Code Forum 11 04-11-2009 09:14 PM
load calculations Please Help powerline General Electrical Discussion 1 03-04-2009 08:44 PM
Service Calculations. agoolay General Electrical Discussion 4 04-07-2007 02:36 PM
