480V photocell wiring diagram - Electrician Talk - Professional Electrical Contractors Forum
Old 02-23-2012, 09:39 PM   #1
Default 480V photocell wiring diagram
Hello, new guy here - I'm an electrical designer at an engineering group that provides engineering and drawing packages for oil producers here in Bakersfield Ca.
I have a question: I am looking for a remote photo cell wiring diagram for a 480V single phase fixture.
The application is a single 400W HPS 480V (single phs) pole mounted light fixture on a wooden power pole. The fixture will be fed from a 15A molded case circuit breaker in a 3r enclosure at ground level on a plywood back board where power is distributed to 2 MOVs (motor operated valves). I am not controlling a contactor, and there is no available 120V control power and no neutral - just 480 delta.
I know I can install a plug-in photocell on the fixture, but I would instead like to install a remote photocell at the breaker enclosure so the electrician can defeat it from the ground to periodically check the fixture.
I suppose I could always wire in a push-button momentary switch at the breaker box that would be pre-wired to by-pass the photocell up at the fixture, but having the electrician alter the wiring of the fixture at installation doesn't appeal to me.
I am putting together a drawing package and I need a schematic. I find nothing on Intermatic's web site - everything is either 120/277 or 208V to a contactor coil. Does anybody have a diagram? A part number would be nice too!
Thanks in advance,
Greg a.k.a. "The Highlander"
Hilandr451 is offline   Reply With Quote
Old 02-24-2012, 01:14 PM   #2
You could install a 2 pole 600v rated switch to by pass the remote photo eye as long as the phasing and circuit is the same.
MasterE is offline   Reply With Quote
Old 02-24-2012, 01:34 PM   #3
RIP 1959-2015
HARRY304E's Avatar
Rewards Points: 1,344
Thanks in advance,
On a single phase 480 volt photo control the wiring diagram is the same just that the white wire turns into Line 2 instead of a neutral.
http://www.sensorswitch.com/DataSheets/TLP.pdf
http://www.precisionmulticontrols.co...atalogue09.pdf
http://www.precisionmulticontrols.co...Photocell.html
Welcome to the forum.....
Old 02-24-2012, 03:16 PM   #4
Thanks guys I see that there is no difference between the 120/208V wiring and the 480V stuff. The photocells still only break one leg to the light. I would need to use a contactor to achieve that.
I'm going to go with a single remote photocell down at the ground level and hope nobody notices. With a lockable means of disconnect on the ground, it shouldn't be a safety concern. What I'm trying to accomplish here, with minimal cost to the client, is for the maintenance electrician to be able to test the light without having to bring a bucket truck to the site.
Thanks again!
-Greg
Old 02-24-2012, 08:45 PM   #5
How about a bypass switch? That's the way to go, regardless of how you feel. Electricians are professionals! Give us the power and the responsibility man.
kaboler is offline   Reply With Quote
Old 02-24-2012, 09:56 PM   #6
erics37's Avatar
Rewards Points: 638
You probably will have a tough time finding a stem-mount or button photocell good for 480V. You can get one of these:
(Intermatic LC4535)
and one of these:
(Intermatic K122)
Your electrician can jimmy-rig it all together, that's what we do.
The Following User Says Thank You to erics37 For This Useful Post:
IBEWRockstar (03-06-2012)
Old 02-25-2012, 12:45 AM   #7
He wants to take the power out of an electrician and put it in the hands of an... engineer. Scary hahahaha.
Old 02-25-2012, 01:03 AM   #8
RIP 1959-2015
HARRY304E's Avatar
Go back to bed..
Old 02-25-2012, 01:05 AM   #9
erics37's Avatar
Rewards Points: 638
BBQ (03-09-2012)
Old 02-25-2012, 10:05 AM   #10
(Intermatic LC4535)
and one of these:
(Intermatic K122)
Yes they do make them and no problem getting them..http://precisionmulticontrols.com/Ph...-ETseries.html
And they also have this..http://precisionmulticontrols.com/relays/relay2.html
The Following User Says Thank You to MasterE For This Useful Post:
erics37 (02-25-2012)
Old 03-05-2012, 10:53 PM   #11
freeagnt54's Avatar
Rewards Points: 966
All I can say is that those intermatic 480v stem mount photocells are garbage, at least in my experience. I had a similar set up as you all I had was 3ph 480v with no neutral. I had the photocell controlling a contactor and the first three yes three failed within the first 5 minutes and I had to special order them each time.
freeagnt54 is offline   Reply With Quote
Old 03-08-2012, 03:03 PM   #12
Amish Electrician's Avatar
The Intermatic instructions are in error, and you WILL let the smoke out.
Look closer at the ratings. The eye is only rated for 277v to ground. 480 to ground will kill it. The drawings are mislabled.
You want to control 480, use a contactor with a lower voltage to the coil.
Amish Electrician is offline   Reply With Quote
Old 03-08-2012, 09:03 PM   #13
Rewards Points: 5,198
Thanks in advance,
Why not just use a disconnect with a contactor, and a manual test switch? And, of course, a control transformer.
Old 03-08-2012, 10:56 PM   #14
freeagnt54's Avatar
Rewards Points: 966
The box and the photocell itself both say 480v, and what I hooked them up to was only 277v to ground.
Old 04-01-2012, 10:31 PM   #15
Us? You 'n me we's jus' apprentices.
cguillas is offline   Reply With Quote
Old 04-03-2012, 02:01 AM   #16
Rewards Points: 250
http://www.precisionmulticontrols.com/PMCcatalogue09.pdf
great site. seems like you can avoid using a lighting contactor with some of their direct wire photocells.
noarcflash is offline   Reply With Quote
Homeowner Wiring Diagram BIGRED General Electrical Discussion 13 05-12-2010 06:52 PM
generator wiring diagram? ahmedahmedahmed General Electrical Discussion 18 01-27-2010 10:45 PM
Wiring Diagram skyline2500cc UK Electrical Forum 6 10-26-2008 09:14 PM
asking for wiring diagram msrjony Structured Wiring 10 03-24-2008 05:38 AM
help me i need some one to draw me a wiring diagram guitarfchs78 General Electrical Discussion 2 01-28-2008 08:12 AM
