bat wings - Electrician Talk - Professional Electrical Contractors Forum
Like Tree15Likes
  • 2 Post By telsa
  • 1 Post By MechanicalDVR
  • 1 Post By jsmart84
  • 2 Post By drspec
  • 2 Post By splatz
  • 1 Post By telsa
  • 1 Post By sparky402
  • 2 Post By Cl906um
  • 1 Post By freeagnt54
  • 1 Post By sbrn33
Old 01-08-2017, 03:34 PM   #1
Wiresmith
hd13's Avatar
Rewards Points: 266
Default bat wings
do you guys run your own ceiling grid wire for using bat wings or do you use the wire for the ceiling grid. im talking about erico caddy part # kx if batwing isn't the name used everywhere. and if you do run your own wire do you terminate the bottom end to anything? code requires us not to use the wire being used for the ceiling grid. thanks
hd13 is offline   Reply With Quote
Old 01-08-2017, 03:49 PM   #2
Rewards Points: 15,780
We ALWAYS paint and shoot our own #12 ceiling drop wires.
They have to be tied off, too.
It's mandatory around these parts.
Our preference is to pay the ceiling dudes a case of beer -- or so -- to shoot our wires, as it's a skill that takes time to acquire.
hd13 and cl2sparky like this.
hd13 (01-10-2017)
Old 01-08-2017, 05:04 PM   #3
Deplorable-Electrician
Rewards Points: 2,108
I've added my own hangers and hung off of the existing, never been flagged.
cl2sparky likes this.
hd13 (01-15-2017)
Old 01-08-2017, 07:42 PM   #4
Rewards Points: 429
I typically will strap wiring to the wires we put in for our lights. But if in a pinch atach to ceiling grid for limited locations.
jsmart84 is offline   Reply With Quote
The Following User Says Thank You to jsmart84 For This Useful Post:
hd13 (01-15-2017)
Old 01-08-2017, 07:55 PM   #5
drspec's Avatar
Rewards Points: 642
the few times I need to I run my own wire and flag it with red tape
The Following User Says Thank You to drspec For This Useful Post:
hd13 (01-10-2017)
Old 01-09-2017, 04:30 AM   #6
Rewards Points: 3,010
I do some fairly ugly things to follow this rule. I use it as an example of why it isn't just the price of copper that drives prices up over time.
If you haven't seen them, check these out
They're quick and cheap and satisfy the requirement.
The Customer is Always Right! - @Hackwork
hd13 (01-10-2017)
Old 01-10-2017, 07:52 PM   #7
Cl906um's Avatar
Rewards Points: 1,154
What is this?
Old 01-10-2017, 08:18 PM   #8
Rewards Points: 1,480
Skill to pull a trigger? Or just effort?
Old 01-10-2017, 08:23 PM   #9
Originally Posted by Cl906um View Post
What is this?
A colored ceiling clip that identifies your wire end from the ceiling guys.
The Following 2 Users Say Thank You to MechanicalDVR For This Useful Post:
hd13 (01-15-2017), splatz (01-10-2017)
Old 01-10-2017, 08:44 PM   #10
Cow
Rewards Points: 2,478
We have to paint and use our own ceiling wire.
hd13 (01-15-2017)
Old 01-10-2017, 08:51 PM   #11
The grid crew shoots wire at about four times the speed of my boys. We just don't do it often enough to become really proficient.
I break out my own pole only as a last resort. ( I couldn't beer my way through. )
hd13 likes this.
hd13 (01-15-2017)
Old 01-10-2017, 08:51 PM   #12
Going_Commando's Avatar
Rewards Points: 334
Some folks calls em batwings, I calls em mustache clips mmhmm.
Going_Commando is online now   Reply With Quote
Old 01-10-2017, 08:56 PM   #13
sparky402's Avatar
Rewards Points: 524
I try to avoid using them.
hd13 likes this.
sparky402 is offline   Reply With Quote
Old 01-10-2017, 09:56 PM   #14
Cl906um's Avatar
We should have some type of colored cap so at least our wires don't penetrate your eye socket.
hd13 and RePhase277 like this.
The Following User Says Thank You to Cl906um For This Useful Post:
hd13 (01-15-2017)
Old 01-13-2017, 09:32 PM   #15
freeagnt54's Avatar
Rewards Points: 998
https://www.erico.com/part.asp?part=EC311
We use these, often referred to as banana clips.
I always use them when dropping wires but all-thread I don't secure the other end.
hd13 likes this.
freeagnt54 is offline   Reply With Quote
The Following User Says Thank You to freeagnt54 For This Useful Post:
hd13 (01-15-2017)
Old 01-13-2017, 11:15 PM   #16
RePhase277's Avatar
Rewards Points: 4,572
Depends... is it being inspected?
The Following User Says Thank You to RePhase277 For This Useful Post:
hd13 (01-15-2017)
Old 01-24-2017, 12:18 PM   #17
Rewards Points: 507
We shoot our own #12 wires for lighting and raceways.
Attach to the fixture support wires or 1/4 electrical all thread whrer available.
Use 1 size larger for all thread clipping.
The yellow thing is what we call a banana clip.
Well actually a plastic version that I don't see much.
The metal ones are thinner, less interference with the tile.
Also the B-line have a bit of play and preferred compared to the Caddy.
That way you stay solid but don't lift the grid.
The county wants the electrical attached on clips.
Their idea is if the ceiling is pulled down by firefighters the electrical support wires un-clip and stay hanging.
For a suspended hard lids which is very common here, they don't care if we use the ceiling support wires. 300.11 states for ceiling grids, not suspended framed drywall ceilings. For those when we shoot and tie a wire I like to get the guys an angle clip to tie onto and screw into the framing.
B-line clip
https://www.frostelectric.com/buy/pr...Clips/dept-6C0
active1 is online now   Reply With Quote
Old 01-24-2017, 02:13 PM   #18
still in business
sbrn33's Avatar
Rewards Points: 3,490
This is another one of those stupid rules that does not need to be around.
but this is the economically depressed South and we're just a bunch of barefooted cousin humpers.
Old 01-24-2017, 03:02 PM   #19
Profiteer
Rewards Points: 1,188
I have always just spray painted the wires while they were on the ground. Always get to it first so you could use the orange paint that you already have in the gangbox, or else the carpenters will use that color for their own wires lol.
