Bending big wire - Electrician Talk - Professional Electrical Contractors Forum
Old 07-14-2010, 05:18 AM   #1
Mike in Canada's Avatar
Default Bending big wire
Do you folks have any favourite methods for getting big wire to sit properly in the lugs? Even the 14" Klein cable benders only have a capacity of 500 mcm, and I've got 600 and 750 to deal with. I'm just curious what the favoured methods are. I'm not worried about little stuff like #2, just the big stuff.
Mike
Mike in Canada is offline   Reply With Quote
Old 07-14-2010, 05:56 AM   #2
Semper Fidelis
Suncoast Power's Avatar
Rewards Points: 4,590
Mike
Drill a hole in a a few 2x4s at different angles or make up a piece or unistrut with some 3/4" bolts spaced a couple of inches apart.
Or
stick the wire in the end of a piece of unistrut.
Old 07-14-2010, 06:54 AM   #3
I take a piece of 2" EMT and file it real good, then I wrap the end of it with black tape. I make it thick and I go over the edge so that I can fold it back in.
This works better than anything else I'd tried.
BlueBox is offline   Reply With Quote
Old 07-14-2010, 07:21 AM   #4
drsparky's Avatar
Rewards Points: 386
Greenlee cable benders.
http://www.mygreenlee.com/GreenleeDo...c_number=23893
Old 07-14-2010, 07:24 AM   #5
Rewards Points: 150
We have a GREENLEE 800 Hydraulic Cable Bender
Its the only way too go
Wingnut is offline   Reply With Quote
Old 07-14-2010, 07:39 AM   #6
I own stock in FotoMat!
Rewards Points: 6,520
Old 07-14-2010, 08:06 AM   #7
When I was a kid, I used to just bend it and then tighten it up with the long part against my solar-plexus and just pull in with both hands.
I don't know if I could do that again. Most guys used a bender if there was room. if there wasn't, they would use either the pipe or drilled 2x4 method
Old 07-14-2010, 08:44 AM   #8
If I'm using lugs, I usually bend the wire to fit, and take the lug off. Install the wire into the lug, then screw the lug back in place and tighten.
Then fully tighten the lug screw, with the wire already in it.
FWIW, That size wire, I would use crimps instead of lugs.
Dnkldorf is offline   Reply With Quote
Old 07-14-2010, 08:46 AM   #9
Jrannis, that is pretty ignorant with the photo. WTF?
Old 07-14-2010, 08:48 AM   #10
Could you define "ignorant"? If so, you'd know that you used it wrong.
Old 07-14-2010, 09:01 AM   #11
I use alot of things wrong, and have been guilty more than once for butchering the English language.
It happens...
Old 07-14-2010, 09:06 AM   #12
It happens...
I find it amusing when people ignorantly use the word ignorant.
Old 07-14-2010, 09:07 AM   #13
Makes us look ignorant?
Old 07-14-2010, 09:42 AM   #14
Rewards Points: 5,198
I don't know if this would be kosher on construction, or not, but when we have large conductors and the lugs in the panel are kind of close to the top we install an entry box right above the lugs on the top of the panel. You still have to form the wire but it gives you a lot more length of wire to deal with, and then insert into the lugs.
Old 07-14-2010, 04:36 PM   #15
mattsilkwood's Avatar
Rewards Points: 2,006
I've done the same thing. I had one a few months ago with a 1200A breaker and the lugs were about 4 inches from the top of the cabinet.
A lot of these machinery manufacturers could care less about the installers.
I like to use the end of a bender handle to bend wire. It's long enough that you can get good leverage and the end is rounded so it wont hurt the insulation.
A man that will not read has no advantage over a man that can not read.-Mark Twain
Old 07-14-2010, 07:49 PM   #16
Rewards Points: 504
Originally Posted by drsparky View Post
I used those pretty heavily for a couple months last year. They make the job go so much easier and save a hell of a lot of time.
Mike_586 is offline   Reply With Quote
Old 07-15-2010, 12:53 AM   #17
gold's Avatar
Rewards Points: 2,048
Send a message via Yahoo to gold
a hickey with a shoertened handle works great, if you can find one
Define "Anger Management"
“Free at last, Free at last, Thank God almighty we are free at last.”
gold is offline   Reply With Quote
Old 07-15-2010, 01:01 AM   #18
I have a black cat.
Rudeboy's Avatar
Rewards Points: 2,000
You guys are gay, I use my big strong arms.
I don't like to Save time and money.
Old 07-15-2010, 01:13 AM   #19
Originally Posted by Rudeboy View Post
.........I use my big strong arms..
That's so gay. I just hire Chuck Norris, who stares the wire into place.
Old 07-15-2010, 01:25 AM   #20
I have a black cat.
Rudeboy's Avatar
You can't use him because rat guys can't afford union helpers.
(flexes muscles)
extreme bending pvc 90 s nick General Electrical Discussion 22 04-28-2011 08:33 PM
conduit bending video racerjim0 Off Topic (Non Trade) 171 03-29-2010 08:53 AM
Building a Bending Table SlayeR General Electrical Discussion 10 01-11-2010 09:18 PM
Bending 2'' emt... NolaTigaBait General Electrical Discussion 13 03-20-2009 09:49 PM
bending conduit AT Grimaldi Tools, Equipment and New Products 23 10-17-2007 07:57 PM
