Conduit bending issue - Electrician Talk - Professional Electrical Contractors Forum
Like Tree23Likes
Old 02-14-2017, 04:33 PM   #1
Rewards Points: 16
Default Conduit bending issue
Was bending conduit today it was my first time in awhile and had an issue. I had a 2 boxes in a stud cavity and had an offset to connect them. Had both connectors in the boxes and measured off the same stud to the same side of each connector. Every time my offset was too large by 1 inch. I'm confused.
MJFElectric is offline   Reply With Quote
Old 02-14-2017, 06:41 PM   #2
Semper Fidelis
Suncoast Power's Avatar
Rewards Points: 4,314
Like this?
Old 02-14-2017, 06:50 PM   #3
360max's Avatar
Rewards Points: 738
1"pipe
Moderator-In-Training
Old 02-14-2017, 06:58 PM   #4
Rewards Points: 1,402
Bend about 1'' less and it should be perfect.
in Order to form a more perfect Union
Old 02-14-2017, 06:58 PM   #5
Semper Fidelis
He didn't say he was bending a 90 did he?
Was he making a 4" offset and not allowing for takeup?
Old 02-14-2017, 11:41 PM   #6
Rewards Points: 245
Offset too big or small would be from:
1. Actual bent angles not same as desired angle. Such as bending 50 degrees instead of 45.
2. Bender sliped from marks / not exactly on marks when bent
3. Calculation / bend multiplier wrong
4. Marking / measuring mistake
5. Mistake interpreting bender angle marks. Sometimes when you use a unfamiliar bender the angle marks and handle position may be different. Such as a 30 degree bend the handle is straight up on many benders. But some it's 45 degrees straight up.
It don't matter what spot you line up your offset mark on a bender as long as you do both the same.
Maybe you could post your desired offset, bend angle, and distance between marks to check your math.
A level with common bend angles helps to check your bend amount.
Many times you can adjust more or less offset in as long as it's not matching others or exposed.
active1 is online now   Reply With Quote
Old 02-14-2017, 11:56 PM   #7
Rewards Points: 12,650
Don't tell anybody.
Old 02-15-2017, 12:35 AM   #8
Deplorable-Electrician
Rewards Points: 19,474
DJT, making libtards cry since 20 Jan 2017
Old 02-15-2017, 06:06 AM   #9
Rewards Points: 1,672
I'll tell you what I have found myself scratching my head and wasting time on trivial tasks like this more often than I'd like to admit.
I could also tell you that since I bought the wonderful M12 bandsaw, I measure less and trim to fit more, but that would be bull****, I always measured less and trim to fit more even with a hack saw. The size of the scrap pile is about the same, but there are more little pieces fewer big pieces. I use more couplings. There is less bragging but more going home on time.
Old 02-15-2017, 06:14 AM   #10
Semper Fidelis
I get it now, you need to measure back to back to ensure you are allowing for the pipe.
Also, you are measuring the difference or how much the pipe will rise from the bending surface.
You also have to make sure you use the same mark for for both bends, star, notch, arrow, the letter K in the word "back" or what ever you like.
I cant think of another way to make it too long.
Old 02-15-2017, 06:30 AM   #11
If he did a back to back bend rather than an offset measuring as he said, wouldn't it come out an inch too short, not too long?
Old 02-15-2017, 06:57 AM   #12
Semper Fidelis
I thought about that as I wrote it and wanted to capture all of the options we can throw out on this thread. I cant understand "longer" either.
Old 02-15-2017, 11:16 AM   #13
Time is money, a trim and coupling can keep things on pace. No shame in that game.
splatz (02-15-2017)
Old 02-15-2017, 03:53 PM   #14
Garygood is offline   Reply With Quote
Old 02-15-2017, 06:21 PM   #15
Rewards Points: 16
had nothing to do with the length. It had to do with the fact that the offset was too large. don't know what was going on. I even had someone put the numbers into an app and it still was too large. all marks on conduit were correct. I was bending 1 1/4 with a hand bender. bending 22 degree because at 30 my marks were too close. the second mark was in the bend.
Old 02-15-2017, 07:56 PM   #16
Rewards Points: 630
Which type of bender you are using ?
Because there is few differnt way to deal with it.
22.5 degrees ?
How much kick (offset) you try to make ?
Keep in your mind with 1.25" emt bender have either 8 or 10 inch radius so it can affect the offset you are try to hit.
Old 02-15-2017, 08:04 PM   #17
Rewards Points: 340
so the offset was too deep youre saying.
what was too large once you did the calculation? the measurement between the bends?
Local 3 IBEW
chknkatsu is offline   Reply With Quote
Old 02-15-2017, 08:08 PM   #18
Semper Fidelis
Did you think it insignificant to mention that you were bending 1-1/4" at 22 deg?
I'll be in my tent!
MechanicalDVR and glen1971 like this.
Old 02-15-2017, 08:30 PM   #19
Watt Pusher
B-Nabs's Avatar
Rewards Points: 436
So how much 1 1/4" did you burn through in this experiment?
Old 02-17-2017, 05:34 AM   #20
Rewards Points: 16
20'. So not bad at all
Suspending security camera from conduit ElectMe NEC Code Forum 8 02-19-2017 04:20 PM
I Hate Bending Conduit A Little Short General Electrical Discussion 60 10-08-2016 02:53 PM
Conduit Bending by a Pro ppsh General Electrical Discussion 41 10-02-2016 10:42 PM
Level 2 Apprentice Conduit Bending Questions supaTROopa3 Commercial Electrical Forum 19 08-30-2016 02:00 AM
Conduit Bending Do's & Dont's KRZCLV General Electrical Discussion 109 03-05-2016 12:19 PM
