Fire alarm system question - Electrician Talk - Professional Electrical Contractors Forum
Like Tree19Likes
  • 2 Post By frenchelectrican
  • 1 Post By Suncoast Power
  • 3 Post By sbrn33
  • 1 Post By MechanicalDVR
  • 4 Post By B-Nabs
  • 1 Post By farmantenna
  • 4 Post By Signal1
  • 2 Post By Signal1
  • 1 Post By B-Nabs
Old 02-09-2017, 05:23 AM   #1
Rewards Points: 2,746
Default Fire alarm system question
Well,,,,,,, I'm doing a tenant job that has audible sirens, strobing audible sirens, pull gizmo's, stuff like that. Last time I wired up one of these was pretty long ago, like maybe 1987 or so. So ,,, I forget now about the back boxes for the stuff in the typical fire alarm system. My memory says use 4-11/16 boxes for all of it, but I can't remember if it is 1 gang mud rings , two gang , or is it no gang and just bring the box out to the finish? I'm pushed to hustle speed and don't have much time to research. Any input will be most appreciated. Mahalo.
Old 02-09-2017, 06:18 AM   #2
Rewards Points: 534
Hey Mac.,,
Yes you can use 4-11/16 or 4 inch box and most audible and strobe units can use two gang mudring on it. but I advise ya use to the deep boxes much as you can and make sure you get them in red box or paint them red.
The pull station .,, Just dont quote me wrong some do take single gang mudring all it depending on what model pull station being used.
The old strobe lights I done before many moons ago was used on 4 inch octagal box so the modern one I bet it can fit on convental two gang box or two gang mudrings it the same with combo units ( sounder and strobe units )
Pay attetion to the mounting heights on those devices they are kinda picky on the location and heights.
MechanicalDVR and telsa like this.
Old 02-09-2017, 06:23 AM   #3
Rewards Points: 11,138
All of the cable is a pig for space.
It's common for extra-sized boxes.
As in 4s deep PLUS a 4s extension
Having rescued more than a few 'astray' F/A systems...
I'll shut up for now.
Old 02-09-2017, 06:55 AM   #4
Rewards Points: 1,060
I don't do much of it but be careful I definitely see a lot of cluster f***s on recently installed systems, ugly surface mount boxes with extenders stacked on top and devices on the extenders.
I think the a lot of devices are made to mount directly on a four square box, but not all. I think wiremold alarm device boxes mount on top of a four square.
Garvin makes what looks like a more flexible 5 1/2" surface mount box that accepts different size devices and mounts to give you more flexibility.
I think maybe DEEP four squares even with the finish would probably work for a lot of systems, maybe need the wiremold / garvin to take up the slack if not.
telsa (02-11-2017)
Old 02-09-2017, 07:00 AM   #5
motherplucker
chicken steve's Avatar
Rewards Points: 3,326
FA's became an attachment license in VT about 15 yrs ago w/ceu's etc
chicken steve is online now   Reply With Quote
Old 02-09-2017, 08:02 AM   #6
Semper Fidelis
Suncoast Power's Avatar
Rewards Points: 3,798
We put deep boxes flush with the finish for horn strobes, 7' or as called out on the plans,
Deep boxes with single gang for the pull stations.
That should get you there.
As for the red paint, we do it just to keep people out of them.
sbrn33 likes this.
“If one would give me six lines written by the hand of the most honest man, I would find something in them to have him hanged.” — Cardinal Richelieu in 1641
Old 02-09-2017, 09:29 AM   #7
still in business
sbrn33's Avatar
Rewards Points: 1,684
Yea, I just use deep 4 sq's with brackets. 2 gangs for strobes, single gang for pull stations and round for detectors. Never once had a problem with over fill, one wire in and one wire out.
You gonna love the new alarm systems,especially if it is addressable.
It's just that simple
The Following User Says Thank You to sbrn33 For This Useful Post:
Suncoast Power (02-09-2017)
Old 02-11-2017, 01:57 AM   #8
Deplorable-Electrician
Rewards Points: 16,304
What do you mean extensions?
telsa likes this.
DJT, making libtards cry since 20 Jan 2017
telsa (02-11-2017)
Old 02-11-2017, 02:18 AM   #9
Watt Pusher
B-Nabs's Avatar
Rewards Points: 278
I would put in just a little time to research your particular system. The different manufacturers are all over the map in terms of how their different devices mount, and how much space they may take up within the back box.
Old 02-11-2017, 08:01 PM   #10
Rewards Points: 232
Why is everyone suggesting to use or do use extra deep boxes? old Simplex fire alarm equipment is gone . I do alot of fire alarm and I use standard 16,18 or 22 cu in 1-gang plastic box if non mc and 1-1/2" 4 sq with 1-gang ring for pulls and horn strobes and 2-1/8" deep 4sq without ring for flush modules
the IDC or SLC wires will be 18 or 16 ga and NAC cables 16-2 to 12-2 and the devices don't need alot space.
farmantenna is offline   Reply With Quote
The Following User Says Thank You to farmantenna For This Useful Post:
splatz (02-11-2017)
Old 02-11-2017, 08:26 PM   #11
Signal1's Avatar
Rewards Points: 374
Agreed. Fire Alarm is my specialty. Everything is a lot smaller now. It's all data now.
Most horn strobes come with with a backplate that pretty much mounts to anything, and the H/S doesn't extend into the box at all.
I can see Bunker Hill from my house!
Signal1 is online now   Reply With Quote
The Following 3 Users Say Thank You to Signal1 For This Useful Post:
360max (02-15-2017), splatz (02-11-2017), telsa (02-15-2017)
Old 02-15-2017, 07:27 PM   #12
Rewards Points: 22
Depends on manufacturer and device. Edwards ceiling mount strobes and speaker/strobes only mount on 4square boxes, and the speaker/strobes stick into the box maybe more than an inch.
Jarp Habib is online now   Reply With Quote
Old 02-15-2017, 08:22 PM   #13
Signal1's Avatar
Rewards Points: 374
I do agree there are many configurations, but my point was that typically you don't need all those deep boxes any more.
Voice evac systems with speakers do need a little more room.
MechanicalDVR and 360max like this.
The Following User Says Thank You to Signal1 For This Useful Post:
360max (02-15-2017)
Old 02-15-2017, 09:36 PM   #14
Watt Pusher
B-Nabs's Avatar
Rewards Points: 278
I just finished wiring an entire apartment building with Simplex speakers, and I can tell you that we needed to use very deep boxes (we went with deep 4x4 with shallow extension because for some reason in Canada 3 1/2" deep 4x4 boxes don't seem to exist). That is why I would recommend anyone installing a fire alarm find out what the devices they are going to be installing will require, so that they don't end up having to do a bunch of work to fix their rough-in, or end up with some hacked together workaround. I agree that most devices these days are much smaller than they used to be. It's just that most ain't all, is all.
Fire alarm guy hancholo General Electrical Discussion 10 06-20-2016 06:56 AM
fire alarm bell connected to receptacle cct PlugsAndLights General Electrical Discussion 4 06-03-2016 10:57 PM
New To Fire Alarm LanceBass General Electrical Discussion 3 04-14-2016 07:20 AM
Fire Alarm How To Book LanceBass General Electrical Discussion 19 03-26-2016 05:40 PM
Mircom Fire Alarm darren79 Canadian Electrical Code Forum 8 02-25-2016 12:33 AM
