Hand Bending Rigid - Electrician Talk - Professional Electrical Contractors Forum
Old 06-19-2013, 07:33 AM   #1
Rewards Points: 164
Default Hand Bending Rigid
When hand bending pipe, is the take off based on the pipe or the shoe? If I'm bending 1/2 rigid with 3/4 EMT bender, what do I use as my take off?
Appreciate any help with this...
gotshokd666 is offline   Reply With Quote
Old 06-19-2013, 07:39 AM   #2
Rewards Points: 250
Deduct is based off the shoe
local134gt is offline   Reply With Quote
Old 06-19-2013, 08:48 AM   #3
Rewards Points: 634
Based on my experience the only way is to bend a scrap piece and determine the deduct from that.
The deduct for a piece of rigid may be different from thinwall even if bent on the same shoe.
bill39 is online now   Reply With Quote
Old 06-19-2013, 12:39 PM   #4
Michigan Master's Avatar
Rewards Points: 1,260
This is from the Ugly's book (a good general reference for many topics).
Michigan Master is offline   Reply With Quote
Old 06-19-2013, 01:10 PM   #5
ponyboy's Avatar
Rewards Points: 707
This
Old 06-19-2013, 01:28 PM   #6
Rewards Points: 164
Originally Posted by ponyboy View Post
This
Yeah, I just learned that for myself the hard way...! Thank anyway!
That is for EMT. My question was if the same take off applies to rigid...
Old 06-19-2013, 07:38 PM   #7
You are using a 3/4" EMT bender; deduct is 6" for a stub.
Often times people who havenít bent much pipe will have a slightly different deduct than whatís specified (especially when bending RMC); much of this variance is often due to failure to maintain proper foot pressure, and you can see it in the radius of the resulting bend.
Old 06-19-2013, 08:12 PM   #8
Electron Flow Consultant
sparky970's Avatar
Rewards Points: 952
If you want to know the real take-up, bend a scrap piece. If you go with what the bender says, you'll end up bending a test piece anyway.
Old 06-19-2013, 08:14 PM   #9
sparky970's Avatar
Rewards Points: 952
How would you explain the variance in an electric bender? Over voltage or undervoltage?
Old 06-19-2013, 08:56 PM   #10
Once you've done it a few times you should remember the deduct.
There may be some variance in conduit spring back if from different manufacturing runs. The amount of wear a shoe has will also be a factor if using different benders.
Old 06-19-2013, 10:57 PM   #11
Rewards Points: 4,858
This is why a lot of guys put their name on the benders shared by everyone. Not that they are di**s, but that they took the time to actually learn the nuances of the bender, and don't want to have to do it again.
Old 06-26-2013, 06:03 AM   #12
This might have changed with the modern improvements in benders, but it's hard to bend an offset in emt with a bender that has been used for bending rigid. Something about the hook at the end of the shoe being twisted makes it difficult to line up the bends.
xlink is offline   Reply With Quote
Bending Rigid EMT (Canada) Aryan General Electrical Discussion 13 10-19-2014 04:11 PM
Wanted: rigid bending shoes midwesterner Electrician Swap 1 04-23-2013 12:33 AM
Min. For rigid JmanAllen NEC Code Forum 4 09-29-2011 12:23 PM
Bending 1000 is like bending rebar!!!! N.O.L.A. General Electrical Discussion 37 06-27-2011 10:36 PM
Wanted: Greenlee No. 854 3/4" IMC, Rigid Aluminum Hand Bender Kris Davis Electrician Swap 0 05-15-2011 06:13 PM
