Kohler Generator PM ?
Looking through the specs of a job I'm bidding, it says the following regarding a new Gen Set:
"Beginning at Substantial Completion, provide 12 months' full maintenance by skilled employees of manufacture's designated service organization. Include quarterly exercising to check for proper starting, load transfer, and running under load. Include routine preventative maintenance as recommended by manufacture and adjusting as required for proper operation. Provide parts and supplies same as those used in the manufacture and installation of original equipment."
In a different section, it states a factory trained tech needs to perform start up. How would you bid this? 3 additional quarters should satisfy this requirement, correct?
