06-03-2009, 09:24 AM
Little pipe runs
06-03-2009, 10:11 AM
Burger Flipper
Those are some awesome pics, GOt more? Story behind this? That is som eimpressive work there.
~Matt
06-03-2009, 10:12 AM
Seen your member
Originally Posted by Loose Neutral
But you still have the memory and the photos. That's what counts.
And welcome to the forum!
06-03-2009, 10:54 AM
17' Below FF, why so deep? Most impressive by the way.
06-03-2009, 02:06 PM
My Fault. That particular run was maybe the 4th or 5th layer of pipe. The first layer was the high voltage and it was 17' below FF. Nice 4 point saddle though. Had to make way for another pipe run that was going to intersect.
06-03-2009, 03:46 PM
Zen Student
Impressive. Most impressive. I love pipe runs. Good pipe runs that is.
06-03-2009, 03:53 PM
Seen your member
At 17' BFF, I don't think you want to f  k anything up.
06-03-2009, 04:04 PM
Not Peter D
A strut rack for a buried duct bank?
Must be government work.
06-03-2009, 04:19 PM
Unlimited Lic.Electrician
No just someone that takes pride in his work.
06-03-2009, 04:20 PM
Good looking work.  And welcome to the forum.
06-03-2009, 04:22 PM
Not Peter D
Pride has nothing to do with this. My point was that money is no object on this job apparently.
06-03-2009, 04:46 PM
one reason for the strut is to keep it level and that many pipes can crush or twist plastic chairs. keeping it level will be real important when stubbing up. seems like a simple thing but trying to stub up a neat rack is LOTS easier when pipes are level and spaced apart . NOT crammed together.
06-03-2009, 04:50 PM
With all of those ridged 90's it would be a whole lot faster to use the strut than not. He might of spent the small amount of money on the strut and saved a whole lot more in labor.
06-03-2009, 04:53 PM
Not Peter D
OK, I understand the need for the rack. The scope/size of this project makes me think this is a government or military project.
06-03-2009, 04:55 PM
Yea I agree. Might be a data center. If the op is still here what type of job is this?
06-03-2009, 04:59 PM
Hey Loose Neutral what do you plan on using to backfill with? Around here we use concrete or washed / 57 stone.
06-03-2009, 05:01 PM
Not Peter D
Yeah, could be that too.
06-03-2009, 05:04 PM
#18
Not Peter D
I was wondering that as well, a great place to use 'followable fill'
http://www.flowablefill.org/
06-03-2009, 05:06 PM
#19
another reason for the strut is when ( if ) the duct bank is poured the pipes dont float. has to be real wet concrete to vibrate all thru that rack.
06-03-2009, 05:45 PM
#20
Slurry mixture consisting of mostly a sand with a little portland cement no stones at all. Has to be real wet to get to the bottom of those racks. Once dried it's hard compacted sand. then a layer of good select rolled and tamped. then the next layer of piping.
Has to support a lot of pipes and guys walking on the racks. Then the slurry mixture getting dumped from above. The concrete trucks were coming in full and dumping in about 3 minutes. It worked out well.
sorry about the mess on these quotes trying to figure this out new to this.
| Thread |
Thread Starter |
Forum |
Replies |
Last Post |
Pipe threader
TOOL_5150 |
3 |
03-20-2009 11:25 PM |
pipe insulation
Jacksonville |
Workplace Safety |
3 |
07-30-2008 12:56 AM |
Pipe racks
Bkessler |
3 |
03-16-2008 05:23 PM |
Bendin' Pipe!!!
leftyguitarjoe |
74 |
04-01-2007 08:31 AM |
pipe as ground????
Mark Henderson |
NEC Code Forum |
11 |
01-31-2007 10:02 PM |
