Old 04-11-2012, 03:26 PM   #1
Default voltage question
i was wondering on a 120/208 3 phase system, phase to phase is 208v and phase to neutral is 120v why is this shouldnt phase to neutral be 104v? i know it is this way im just wondering why
Julius793 is offline   Reply With Quote
Old 04-11-2012, 03:55 PM   #2
Cletis's Avatar
Default this and dat
here
www.cletiselectric.com
Old 04-11-2012, 05:16 PM   #3
Not here at the moment
Dnkldorf's Avatar
You forgot to add the 16V back into the equation.
Rookie mistake.
Dnkldorf is offline   Reply With Quote
Old 04-11-2012, 05:55 PM   #4
BBQ
BBQ's Avatar
With 240 the two legs are exactly opposite each other, in other words 180 degrees apart from each other.
With 208 the phases are not 180 degrees apart they are each 120 degrees aprt from each other, that means you figure it differently.
As always with 3 phase 1.73 comes into it.
120 volts x 1.73 = 207.6 volts.
BBQ is online now   Reply With Quote
Old 04-11-2012, 08:38 PM   #5
thanx guys
Old 04-12-2012, 01:19 AM   #6
Julius793.,
Just let you know it is the same way as 480Y277 volts so let ya know that one as well.
Merci,
Marc
Typical low voltage guy asking high voltage question. LARMGUY General Electrical Discussion 13 09-02-2010 12:59 AM
Voltage/Hz question msteph PLCs, VFDs, Motors and Controls 10 04-29-2010 02:31 PM
Voltage Question jontar NEC Code Forum 8 10-12-2009 11:53 AM
voltage question BuzzKill General Electrical Discussion 5 12-02-2008 10:41 PM
voltage question BuzzKill General Electrical Discussion 10 12-02-2008 07:02 PM
