Old 08-09-2012, 07:38 PM   #1
Default Water resistant/proof electrical work?
I work for a company where the room is power washed with water and needs a light in it. What is the best way to go about this? Will compression couplings be enough to keep water out?
henderson14 is offline   Reply With Quote
Old 08-09-2012, 08:35 PM   #2
Industrialsparky's Avatar
Run liquid tite
Industrialsparky is offline   Reply With Quote
Old 08-09-2012, 09:59 PM   #3
Would EMT with compression couplings work?
Old 08-09-2012, 10:06 PM   #4
i would not run emt in a washdown area at all. compression couplings wont do you any good when the emt is rusting through. use pvc or rigid and vapor tight fixtures
D-Bo is offline   Reply With Quote
The Following User Says Thank You to D-Bo For This Useful Post:
Big John (08-10-2012)
Old 08-09-2012, 10:14 PM   #5
still in business
sbrn33's Avatar
PVC with car flex where required. Vapor Tight flour when you need light.
Stop trying to think logically, it won't help you here. Just do as we say and everything will be alright.
Old 08-10-2012, 08:09 AM   #6
Why not PVC with FSC boxes? That's how we used to do the hog barns.
Stickshaker is offline   Reply With Quote
The Following User Says Thank You to Stickshaker For This Useful Post:
denny3992 (08-10-2012)
Old 08-10-2012, 09:57 AM   #7
erics37's Avatar
I do a lot of work in wash-down areas at the local fish plants. It's almost exclusively PVC with carflex. Weatherproof covers for everything. It's basically like installing stuff outside. Here though we have to use stainless steel for any hardware (panels, boxes, screws, etc) because the proximity to salt water eats anything else in very short time. EMT with compression couplings won't cut it.
I would be sure to stick a drain fitting in the run somewhere too because no matter how hard you try, something will fill up with water.
Old 08-10-2012, 10:36 PM   #8
Electricity is Amazing!
thoenew's Avatar
The hog barns we do are always pvc and weatherproof. Only place is the mechanical room, even though we still use the same covers and such because that's what's on the jobsite.
thoenew is offline   Reply With Quote
Water proof enclosure Bigdave General Electrical Discussion 13 08-23-2011 06:48 PM
water or electrical fire Darrin General Electrical Discussion 16 06-19-2011 01:14 AM
Fire resistant electrical insulation void269 General Electrical Discussion 12 02-16-2011 11:38 AM
Tamper resistant vs weather resistant Foestauf General Electrical Discussion 25 01-12-2011 06:33 PM
Electrical work in the water. Sparkee General Electrical Discussion 20 09-23-2009 11:18 PM
