10-04-2009, 11:54 AM
I am a RAT.
X-fmer's roughed in the slab
Do any of you rough your x-fmers in the slab if it is possible or do you just flex them in?
10-04-2009, 12:05 PM
I am a RAT.
Here is are some pictures of a baby x-fmer that I roughed in the slab.
10-04-2009, 12:09 PM
I always use flex in case it has to be changed.. being fed from the bottom is a real PITA when you don't have use of a fork lift
10-04-2009, 12:11 PM
Ratus Maximumus
I have not , but if the opportunity presented itself I would not hesitate. I have dropped down to floor below and back up again.
Bob Badger
Electrical Construction and Maintenance
MA, RI, CT
10-04-2009, 12:15 PM
Rat Extraordinaire
Depends on the job. If I have the opportunity, yes. But some jobs, like precast mezzanines, don't lend themselves to it.
10-04-2009, 12:17 PM
Why would they bottom feed them that way to begin with?
Seems like really poor engineering for something that weighs hundreds of pounds
10-04-2009, 12:19 PM
I am a RAT.
Thats the way I do it also. PVC is a whole lot cheaper than flex 90's.
10-04-2009, 12:21 PM
Ratus Maximumus
It keeps the transformer from cooking the insulation on the conductors.
I have wired a 1000 KVA that was top feed but there was a ton of air space and venting.
Bob Badger
MA, RI, CT
10-04-2009, 12:29 PM
I am a RAT.
It is a whole lot easier to pull the wire when it is in the slab than fight those 90 degree flex conn. I rough mine with 2 90's back and if you tape the wires together and push the wire so that the wire is curled the way the 90's are going the wire will come right out of the other end.
10-04-2009, 12:32 PM
Rat Extraordinaire
What does the weight of the equipment got to do with it? The only problem with weight you could possibly have is if the floor is poorly engineered. I've installed switchgear that far outweighs any transformer in the room and it's bottom fed....
10-04-2009, 12:39 PM
I am a RAT.
Here are some photos of the panel's that are on the opposite wall.
10-04-2009, 12:44 PM
I am talking about having to change the transformer
The ones in the pic, I could use a hand truck to get it out of the space
With bottom feed, that option won't work
10-04-2009, 12:46 PM
Rat Extraordinaire
How often does this actually happen?
10-04-2009, 12:47 PM
I am a RAT.
My exact thought. I have never had to replace a x-fmer.
10-04-2009, 12:52 PM
Rat Extraordinaire
When I designed my house, everyone told me I was nuts for not having the garage right off the kitchen. I asked why I needed to do so. Everyone said "So when you replace your refrigerator, it will be easy to get the new one in and the old one out!"
I have yet to replace my fridge, and will probably do so only once in the remainder of my life. I would prefer to have a house designed around the things I do every day, like cook, do laundry, sit at the computer and post on ET...........
10-04-2009, 01:06 PM
So far, I have had to change (3) of them
One was being fed from the bottom with 500 cu and I will never do that kind of job again.. total PITA bending wires to make them fit
10-04-2009, 01:07 PM
Rat Extraordinaire
Mebbe you should start supplying better transformers, then.
10-04-2009, 01:13 PM
#18
Mine are all still working fine, it was the other guy who was supplying cheap transformers
10-04-2009, 01:23 PM
#19
I am a RAT.
....., sit at the computer and post on ET...........
You know thats right.
10-04-2009, 01:51 PM
#20
Rat Extraordinaire
Then thank him for the work.
