Old 10-04-2009, 07:34 PM   #21
Default nice transformer pics!!
Please unconfuse me about some of the wiring:
This first pic looks like transformer is wired for 480 delta to 208 wye
In the next one, the connection looks like 480 wye.
It just seems unusual to me that you would have 480 delta and wye in the same installation.
What am I missing?
Thank you
EJPHI
Old 10-04-2009, 08:49 PM   #22
I am a RAT.
william1978's Avatar
You didn't miss anything. The transformer doesn't need a neutral on the primary side it is recreating the neutral for the secondary side. I'm going to see if I can find a wiring digram.
Old 10-04-2009, 08:54 PM   #23
Rat Extraordinaire
Dis do it?
Old 10-04-2009, 08:57 PM   #24
I am a RAT.
Dis do it?
That is what I was looking for. Thanks 480.
Old 10-04-2009, 09:02 PM   #25
When I designed my house, everyone told me I was nuts for not having the garage right off the kitchen. I asked why I needed to do so. Everyone said "So when you replace your refrigerator, it will be easy to get the new one in and the old one out!"
I have yet to replace my fridge, and will probably do so only once in the remainder of my life. I would prefer to have a house designed around the things I do every day, like cook, do laundry, sit at the computer and post on ET...........
That's the reason why I put the garage near the kitchen. We're always taking in groceries and other stuff from the cars, the kitchen is the "headquarters" where everything lands before it is put away.
Decepticon is offline   Reply With Quote
Old 10-04-2009, 09:04 PM   #26
Hey William, I guess in your area you won't get gigged for using white instead of gray for the high voltage noodle?
Old 10-04-2009, 09:06 PM   #27
Rat Extraordinaire
Got a Code reference?
Besides, the noodle is for the 120/208 side, not the 480 side.
Old 10-04-2009, 09:08 PM   #28
I am a RAT.
It is gray tape it does look like white tape in the picture, but even if it was white the inspector couldn't say a thing and it should be that way in your area also.
Old 10-04-2009, 09:09 PM   #29
There's a lot of things that get gigged that aren't in the code.
Not in the picture I am looking at.
Old 10-04-2009, 09:10 PM   #30
I am a RAT.
Are we talking about the x-fmer or the panelboard?
Old 10-04-2009, 09:10 PM   #31
Rat Extraordinaire
There's a lot of things that get gigged that aren't in the code.............
Do you ask for a Code reference then?
...........Not in the picture I am looking at.
Uncle! Which one you looking at then?
Old 10-04-2009, 09:14 PM   #32
I was looking at this picture:
But maybe it's just the coloring on my computer making it look white instead of gray
Old 10-04-2009, 09:18 PM   #33
I am a RAT.
It does look white in that picture. Check it out in the other pictures. It is gray that is what we use on our 480v.
Old 10-04-2009, 09:19 PM   #34
Rat Extraordinaire
I see it as white, too, but I can see where it is overexposed.
Old 10-04-2009, 09:21 PM   #35
Us too, but I have seen and heard about some pretty wacky color coding around the country, which is why I was curious about yours. I'm glad I could go to NC and know WTF is going on
Old 10-04-2009, 09:30 PM   #36
I am a RAT.
Everyone that I know uses gray for highvolt and white for lowvolt. We do have some delta highleg in some of the older area's. So whenever you fell like moving come on over to N.C..
Old 10-04-2009, 09:38 PM   #37
Rat Extraordinaire
Just wait until you find gray that was installed (legally!) as an ungrounded!
Old 10-04-2009, 09:40 PM   #38
I am a RAT.
Haven't yet, but who know's oneday I just might.
Old 10-04-2009, 10:10 PM   #39
Senior Moment
rlc3854's Avatar
Check out the other three cables in the upper left side. They look gray
rlc3854 is offline   Reply With Quote
Old 10-04-2009, 10:12 PM   #40
I've changed out maybe 3 or 4 transformers that were bottom fed so far. The smallest was likely a 15 KVA, the largest was a 300.
It's really not all that hard, just spoon it up onto some blocks, a little on each side at a time. Get it high enough to put some short pieces of 4" or 6" rigid under the end rails, and try to not skin up the wires as it rolls out.
That can be sort of hard if they're 500s. Some transformers you can take the bolts out of the back of the bottom plate, and tip it up a bit. This helps more than you'd think; not only do you have more clearance, but the holes in the bottom plate are now angled slightly to your favor.
If the transformer is on a housekeeping pad, this method becomes much more difficult. It's best to build something up to the height of the pad, so the pipes have something to roll out onto. A couple of 4x8s work pretty good.
Having more than one person helps a bunch. 3 of us did the 300, it went pretty well.
If the transformer isn't too heavy, a cherry picker (the kind used to pull a car engine) is the absolute best possible way, if it'll fit in the room, and straddle the pad.
Rob
PVC MC cable in pvc conduit under slab? nealla General Electrical Discussion 17 09-09-2008 04:27 PM
slab construction requirements rebel34 General Electrical Discussion 4 01-27-2008 08:47 AM
Underground work and slab on grade MDShunk NEC Code Forum 4 01-28-2007 09:38 PM
