Old 04-28-2012, 09:55 PM   #21
magneticpersona's Avatar
well there, straight for the horse's mouth! nice research Ontariojer
For perfect electrical work at a great price!
www.absolutelyperfectelectrical.com
magneticpersona is offline   Reply With Quote
The Following User Says Thank You to magneticpersona For This Useful Post:
Ontariojer (04-28-2012)
Old 04-28-2012, 10:00 PM   #22
Gold Member
Very gracious! Usually I am the horses ass
Ontariojer is offline   Reply With Quote
Old 05-11-2012, 10:43 PM   #23
Originally Posted by Ontariojer View Post
I may be wrong here, but i'm pretty sure you will find that's a #10, maybe #8 bond with the #6 conductors.
Correct. I have done many hot tubs with #6 T90 and #10 bond. Passed every time. Mind you if the run was long I would use #8 to be sure of a low impedance path.
Anyone who has never made a mistake, has never tried anything new.
mr_electrician is offline   Reply With Quote
Old 05-11-2012, 11:10 PM   #24
[quote=farlsincharge;699558]Does everyone do it?
We always have, but after studying the code some more I'm questioning whether it is really required.[/quote } The bonding you are talking about goes from where to where?
Old 05-11-2012, 11:12 PM   #25
The bonding you are referring to goes from where to where?
Old 05-14-2012, 11:08 PM   #26
Default Bond those metal parts!
Rule 68-400 to Rule 68-408 in the CEC covers spas and hot tubs. And yes my interpretation is that if there are any metal parts to this hotub it needs the number 6 bond. Also note Rule 68-406 LEAKAGE CURRENT COLLECTORS. This is a requirement in many hot tubs exception being subrule (4). These leakage current collectors also require a bond. Subrule (5)
westwind is offline   Reply With Quote
Old 05-14-2012, 11:21 PM   #27
Bababoee
captkirk's Avatar
ive always done it and have been required to... even if the motor is double insulated...with no lug and all plastic housing... they want it there in case they change the motor later on.
Full time Bovine Scatologist.
Old 05-14-2012, 11:31 PM   #28
Default My extra few cents.
Subject to interpretation... Rule 68-402 subrule (1) sends us to Rule 68-058 where we might be able to use a bonding conductor sized from Table 16 which would be smaller than a number 6. THis is from Rule 68-058 subrule (7)
But that is if we dont interpret our tub as a permanent install. Same Rule 68-058 subrule (4)
Our hot tub is classified as a pool to some degree as stated in rule 68-402 subrule (1) that this rule (68-058) must be applied if metal parts are present.
to bond or not to bond socalelect NEC Code Forum 18 12-26-2011 06:16 PM
My hottub aint working Edrick Off Topic 13 04-17-2011 06:47 PM
bond wire depth jwjrw NEC Code Forum 14 03-29-2011 07:05 PM
sizing bond wire jsb Code Violation Discussion 13 09-06-2009 06:03 PM
