Adding a hot tub to a full/almost full panel - Electrician Talk - Professional Electrical Contractors Forum
Like Tree10Likes
  • 1 Post By Canaduh
  • 3 Post By spinninwheels
  • 1 Post By PlugsAndLights
  • 1 Post By 99cents
  • 2 Post By sbrn33
  • 1 Post By frenchelectrican
Old 09-08-2016, 10:06 PM   #1
Rewards Points: 168
Default Adding a hot tub to a full/almost full panel
Just a scenario that we were discussing at work today.
Homeowner calls you and asks to hook up a hot tub but their 100 amp panel is full or has one panel slot free, basically they cannot fit a double pole breaker in the panel.
You notice its a Siemens panel and it's also full of tandem breakers with the exception of 3-4 regular sized 15 amp breakers.
Should this service be upgraded the service to 200 amps or would it be to code to swap out 2 of the regular 15 amp breakers for a 15/50/15 quad?
At what point is it a requirement to upgrade the panel or service or is a service upgrade never enforced by the code?
Pardon my ignorance and I should probably already know the answer to this question but I do not.
Majewski likes this.
Canaduh is offline   Reply With Quote
Old 09-08-2016, 10:21 PM   #2
spinninwheels's Avatar
Rewards Points: 673
What does a load calc say, hypothetically?
life is a wild adventure or nothing - helen keller
spinninwheels is offline   Reply With Quote
Old 09-08-2016, 10:34 PM   #3
Safety Pin Member
PlugsAndLights's Avatar
Rewards Points: 2,556
@spinninwheels is right. Bit of a pain but putting the numbers into 8-200
is the only way to know. If most of the usual 240V loads aren't on gas
instead (ie water heater), there's not much chance of room for hot tub
load, but the numbers will tell the story for sure.
P&L
spinninwheels (09-08-2016)
Old 09-08-2016, 10:47 PM   #4
Big nosed attic troll
Majewski's Avatar
Rewards Points: 1,696
I walked into a full 150 service and most were the tandys. Ahj friggin hated the panel and those tandys but didn't say crap about what was there outside of the job. I did a load calc and found what I could splice together and made room. Last option was a sub panel or replace main for a larger one.
The Following User Says Thank You to Majewski For This Useful Post:
Suncoast Power (09-09-2016)
Old 09-08-2016, 10:52 PM   #5
Arrow3030's Avatar
Rewards Points: 122
Load calc! As previously posted. Article 220 and tons of examples in the annex. Use the end of the article, before farms. Part IV I think. There's a nice table in there for adding to existing dwellings. It's very liberal with the demand factors so warn the customer if it's getting close.
Arrow3030 is offline   Reply With Quote
Old 09-08-2016, 11:01 PM   #6
Safety Pin Member
Note to op: this thread would be better suited in Canadian Code section.
P&L
Majewski (09-08-2016)
Old 09-09-2016, 12:14 AM   #7
Rewards Points: 168
P&L
Thanks how can it be moved to the camadian forums?
Old 09-09-2016, 01:00 AM   #8
Rewards Points: 8,150
Doesn't matter. NEC and CEC are going to tell you the same thing. Definitely do the load calc but it's doubtful a hot tub will tip it to a service/panel upgrade. Nothing wrong with putting in tandems but subs are easy. Don't go for a cheesy 4/8 sub. The difference in cost to a 12/24 is almost nothing.
Old 09-09-2016, 01:36 AM   #9
And those plastic Square D spa packs are pathetic. Go with Siemens or Eaton.
Old 09-09-2016, 06:04 AM   #10
motherplucker
chicken steve's Avatar
Rewards Points: 5,208
I've a number of Hot h20's who's 40/50/60A sequencer option allowed it to squeak by the demand load calc @ the 40 setting on a 100A service.....
Oh and, don't listen to the manufacturers statistical power usage song/dance , there's a lot more tubs in warmer clims to offset those #'s
chicken steve is online now   Reply With Quote
Old 09-09-2016, 05:55 PM   #11
Safety Pin Member
Don't worry about it Canaduh. Maybe for next Candian code thread.
P&L
Old 09-09-2016, 06:49 PM   #12
still in business
sbrn33's Avatar
Rewards Points: 2,744
I have done this a ton of times. I always let them know that they need a new service and about 2 out of 10 will do it. The problem with these jobs is normally they buy a used one and can't afford to wire it. Get your $ up front.
Honestly every time I have hooked one up to a 100 amp service I have never had any trouble. Telling them you have to spend $300-$500 just to make it work can sometimes sell the service change.
Old 09-10-2016, 12:38 AM   #13
corn-fused
papaotis's Avatar
Rewards Points: 322
square D makes a 240 / 2-120 breaker that fits in the space of two breakers. does anyone else have those?
Old 09-10-2016, 12:45 AM   #14
Rewards Points: 794
Ya talking about the quad verison ? ya I know it useally found in homeline verison but the QO I doubt it .,
electricguy likes this.
Old 09-10-2016, 02:10 AM   #15
Rewards Points: 1,828
you mean a 120/240 V slash breaker ?
Old 09-10-2016, 02:14 AM   #16
oops was wanting to start a new topic
Old 09-10-2016, 02:16 AM   #17
Deplorable-Electrician
Rewards Points: 24,758
Fairly often I bet there are heater repairs in the not so distant future.
Old 09-10-2016, 08:38 AM   #18
Majewski's Avatar
What's this one?
different panel from same switch gear, & panel feeder and branch circuit question mike883 General Electrical Discussion 32 09-05-2016 02:50 PM
Can I use old breaker panel as a sub panel marshall361 General Electrical Discussion 4 07-09-2016 04:45 PM
Sub Panel Breaker Bakski Canadian Electrical Code Forum 13 06-27-2016 08:16 AM
Calcul maximum electric panel size martindag General Electrical Discussion 12 03-06-2016 05:23 PM
Wiring Left in Distribution Panel Hdinj Code Violation Discussion 26 02-07-2016 11:31 PM
